Radiator Was Leaking
10 replies to this topic
#1 gilbert
gilbert
  • 83 posts
Posted 21 November 2008 - 01:43 am
Had the TDM for 2 months now, love every min of riding on it.. Just that mine is 10 yrs old now, and there are bound to be wear and tear. notice some stains of dried coolant on my engine casing, so i decided to find the root if the problem, traced it back all the way to the radiator, it was leaking between the fins.
Removed the entire radiator and sand down the leaking area.
did a pressure test on the radiator,
(best way to do it at home is in the bathroom, covering all the hole, leaving only one access to the radiator, stick a hose in, and see where the water shoots out from..)
and there were 6 holes!
after i sand down the area and dried it, i apply 2 layer of epoxy (steel Hard), common known as JB weld. leaving for 1hr to dry, then i did a pressure test again. once i confirm that there was no where else leaking, i resprayed the radiator to give it a new look and left it over for the epoxy to fully settle in. fixed everything back, and now my radiator is working great. smile.gif
This method works great for hairline crack, small holes and etc. just thought i share.
Edited by gilbert, 21 November 2008 - 01:43 am.
#2 Magic
Magic
  • 276 posts
Posted 21 November 2008 - 12:38 pm
Good job Gilbert - worthy of being put into the Knowledgebase IMHO - tup.gif
Magic
The bike is faster than the eye or the hand.
Reborn MK1 - rubbish exhaust, dirty engine, missing bolts, missing mirrors, leathal rear tyre, crap carbs - but it doesn't ground out like my old CB750 Custom used to do :-)
Now with DL650 handguards and Garmin Sat Nav
#3 wicklamulla
Posted 22 November 2008 - 02:34 pm
good lad, noice cheap and easy repair.
#4 tdm850rider
Posted 22 November 2008 - 03:14 pm
QUOTE(Magic @ Fri 21st Nov 2008, 07:38 AM) <{POST_SNAPBACK}>
I concur, Is there a 2nd admin vote?
#5 wicklamulla
Posted 22 November 2008 - 03:30 pm
s'just a basic repair to a radiator imho, don't see why it warrants the KB though. cynical ole me huh !
#6 Magic
Magic
  • 276 posts
Posted 22 November 2008 - 05:25 pm
QUOTE(wicklamulla @ Sat 22nd Nov 2008, 03:30 PM) <{POST_SNAPBACK}>
Cos it IS an easy repair, and I would never have thought of doing it - I would have ditched it and bought another radiator - worth going in the Knowledgebase
Magic
#7 wicklamulla
Posted 22 November 2008 - 09:57 pm
QUOTE(Magic @ Sat 22nd Nov 2008, 05:25 PM) <{POST_SNAPBACK}>
#8 tdm850rider
Posted 23 November 2008 - 12:02 am
KB it is then...
#9 gilbert
gilbert
  • 83 posts
Posted 29 January 2009 - 03:29 pm
quick update... after 10000 km, the epoxy is still holding good, even with a off road fall recently... proven solution that helps save money and save your radiator.. smile.gif
#10 JamJar
JamJar
  • 172 posts
Posted 29 January 2009 - 08:44 pm
when doing this , just be carefull that the resin doesnt seep into the hole/crack and block the channel inside , late last year i had to repair a bently that had a similar problem that was fixed by a mobile mechanic , the resin he used completely blocked the fin and somehow caused it to blow
Previous; Kwaka zx10 GSXR Hybrid , ZXR750, Z750,Z400, Honda CB750, CB400, CB250, Yamaha TZR 125 , DT50, 1957 Phillips Gadabout "deluxe" 49 cc pedal and go, scariest thing i ever rode
#11 danceswithmopeds
danceswithmopeds
  • 2,425 posts
Posted 29 January 2009 - 10:04 pm
An aussie mate accidentally drilled a small hole in the rad of his Frontera several years back. He called into me to see if I had any ideas. Coolant had pissed out through the hole by the time he reached me. Did a 'temporary' repair with 2-part epoxy putty and refilled rad with coolant and water to get him over the weekend.
2 years later he sold it, not a drop had leaked out.
Total repair time, about 5 mins.
