Suspension Woes Part 2
58 replies to this topic
#1 Guest_celticbiker_*
Guest_celticbiker_*
Posted 24 April 2009 - 06:41 pm
Mrs CB and I were happily winding our way to work, when, with no traffic coming the other way I made a side road into a chicane
Exhibit A
When at 50MPH and flicking from right to left, bang, scrape, wobble and a distinct smell of melting rubber.
As I slide to a halt I'm thinking collapsed wheel or broken swing arm.
Oh no, no such luck for yours truly.
We get off and this is how it looked.
So, up on the centre stand and OMG, this is not going to be cheap
The two little lugs on the frame have snapped clean in half.
The only thing that saved us was the centre stand acting like a pair of skids.
Exhibit B
Anyway, we got recovered back home and a strip down will ensue shortly.
Failing a repair, it looks like I is going to need a new frame.
Edited by celticbiker, 13 June 2009 - 10:11 pm.
#2 gilbert
gilbert
  • 83 posts
Posted 24 April 2009 - 06:48 pm
oh my, this looks bad...
#3 Guest_Negwedar_*
Guest_Negwedar_*
Posted 24 April 2009 - 07:06 pm
Phew! Glad you're both OK, must have been a buttock-clenching few seconds there...
#4 Guest_celticbiker_*
Guest_celticbiker_*
Posted 24 April 2009 - 07:12 pm
Yeah, didn't know adrenalin was that colour.
#5 munchkin
munchkin
  • 10 posts
Posted 24 April 2009 - 07:23 pm
Blimey,good job you weren't in the middle of a bend !
First thoughts are; did part of the linkage seize thereby transferring load directly to frame lugs ?
I'd be interested to know the outcome,just cos I'm a nosey bugger mind !
#6 TDMick
Posted 24 April 2009 - 09:00 pm
'kin hell mate that must have been an interesting few seconds!
Good save.
Glad you're both ok
#7 TDMick
Posted 24 April 2009 - 09:06 pm
second look
it looks as though the left side of the lug (in picture) has been broken a while and the right side has just given up.
there is some wear on the inner face of the right hand lug and damage at the top, which might indicate a problem that has been around for a while.
Is this a bit of the niner that gets a regular check / lube?
Apart from everyone on here this weekend I mean?
#8 sidestand
Posted 24 April 2009 - 09:17 pm
Glad you're both OK. that looks like it's been waiting to happen for a while CB .................
Now, if you'll excuse me, I'm off out to the garage with me torch .............But on a more serious note, this looks like a Yamaha recall for frame safety checks !
Make sure Yamaha are officially notified & if they don't want to know, inform VOSA
#9 Magic
Magic
  • 276 posts
Posted 24 April 2009 - 09:19 pm
Good save - not sure I would have kept that upright, especially two up!
Had a nasty experience in my Landy on Monday when one of the rear wheels locked up (brake shoe disintegrated) at about 50mph, luckily there was a soft verge...
Magic
The bike is faster than the eye or the hand.
Reborn MK1 - rubbish exhaust, dirty engine, missing bolts, missing mirrors, leathal rear tyre, crap carbs - but it doesn't ground out like my old CB750 Custom used to do :-)
Now with DL650 handguards and Garmin Sat Nav
#10 Guest_celticbiker_*
Guest_celticbiker_*
Posted 24 April 2009 - 09:23 pm
Should do really, but I lubed it 6 months ago and thought I need to ave a look at that on the weekend, then forgot by the time I got home.
Not that looking would have prevented it happening though.
I suppose I could say it's my own fault really, the roads around my locale are awful and I don't slow down or activly try to avoid pot holes or raised iron works( should have an XT ), and I am 2 up most of the time(30 stone).
All that said you still don't expect that to happen.
#11 wicklamulla
Posted 25 April 2009 - 02:48 am
fook me thas scary lookin'. Glad 'he' and 'she' are unwounded.
#12 Nick Apostolakis
Nick Apostolakis
  • 148 posts
Posted 25 April 2009 - 03:05 am
Yeah I think you are lucky to get out from this in one piece. Anyway, can this damage been repaired or you will go for a new frame?
Nick Apostolakis
e-mail: nickapos@oncrete.gr
Web Site: http://nick.oncrete.gr
#13 v8guy
v8guy
  • 420 posts
Posted 25 April 2009 - 09:06 am
QUOTE(celticbiker @ Fri 24th Apr 2009, 07:41 PM) <{POST_SNAPBACK}>
Ouch!
On the other hand, you've just invented the Yamaha DN01
A friend of mine recently noticed his Multistrada sub-frame had sheared; despite it being well out of warranty, Ducati agreed to provide the replacement parts for free... you should get onto Yamaha about that.
v8guy; 2003 TDM900 with added bling: Nitron shock, Racetech fork internals, 17" front wheel, K&amp;amp;amp;N filter, Fuel silencers, PC3, Renthal handle bar, Oxford hot hands, Polisport handguards, Scottoiler (kinda..), Baglux, Givi monorack + pannier rails
My TDM: http://www.gtv8.org/tdm/
Current: 2003 Yamaha TDM900, 2015 BMW R1200RS
Past: Honda CLR125, Honda CB500, Triumph Sprint Sport, Honda VFR750FS, Suzuki DRZ400SM, Triumph Speed Triple 955i, 2015 Honda VFR800X
"Being shot out of a cannon will always be better than being squeezed out of a tube" - HST
#14 ChrisG
Posted 25 April 2009 - 11:35 am
Glad you're both ok. Lucky you've got the centrestand otherwise I guess the sidestand mount would have touched down first and thrown you to the right.
#15 Daveb
Daveb
  • 1,907 posts
Posted 25 April 2009 - 11:58 am
Bloody 'ell CB, close shave glad you 2 are okay, I guess a little shaken up.
Edited by Daveb, 25 April 2009 - 04:31 pm.
2007 Triumph Tiger 955i
#16 dandywarhol
Posted 25 April 2009 - 01:05 pm
Lucky you're ok - good.gif .......I'm with munchkin, my first thoughts were the linkage is part seized - these need taken out and cleaned/greased in UK salty conditions, a lube from the outside won't penetrate (if you pardon the expression wub.gif )
#17 robelst
robelst
  • 1,844 posts
Posted 25 April 2009 - 01:27 pm
QUOTE(dandywarhol @ Sat 25th Apr 2009, 02:05 PM) <{POST_SNAPBACK}>
A good ol' mud-flap and grease-nipples would have prevented that from happening. Then again, modern bikes aren't build to last and every penny that can be saved from manufacturing-cost counts. dry.gif I am still shocked (excuse the pun) though to see this and other (850) shocks snapping, even Buell has the decency to recall and investigate this sort of issue (on the 2nd recall shock on my Buell laugh.gif ).
That was not a banana, Dougal
#18 Guest_celticbiker_*
Guest_celticbiker_*
Posted 25 April 2009 - 01:39 pm
Thanx for your concern everybody, but it wasn't that big a deal really, I rode speedway/grasstrack for 14 years, thus I am used to being out of control.
(That sounds more big headed than it was supposed to)
I do realise it could have turned out a lot worse, and luck did play it's part.
As for the fix, well, I have a plan but think that I will contact Yam UK before proceeding too far as I will need to take a grinder to the frame to remove whats left of the original lugs.
Thanx again guys
Will keep you informed on how this plays out.
Dave B
QUOTE
Bloody 'ell CB, close shave glad you 2 are old I guess a little shaken up.
Eh?
Edited by celticbiker, 25 April 2009 - 01:42 pm.
#19 Daveb
Daveb
  • 1,907 posts
Posted 25 April 2009 - 04:32 pm
sorry CB it was a typo, you can't get the staff today it should have said 'okay'
#20 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 25 April 2009 - 06:38 pm
I agree with the post above - take it to your local Yam dealer and starting making noises about not fit for purpose
Yam may well cough up a new frame as good will gesture
I'm sure they don't want any bad publicity about cracking frames in MCN (who mentioned GSXR1000K5)
