De-restricting Jap Model Mk2/5gg/4tx - 180kph Limit
No replies to this topic
#1 TonyDevil
Posted 03 August 2009 - 09:55 am
original topic here http://www.carpe-tdm...showtopic=13796
QUOTE(springers @ Fri 31st Jul 2009, 07:52 PM) <{POST_SNAPBACK}>
A flash of inspiration and the help of an excellent local mechanic (Jesse James, newport Shropshire) and the points given by you wonderful posters.
The bike is now supporting the UK/4TX ECU and the lights work.....
So for all those with an import Japanese TDM850 marked as a 5GG - this has worked for me
1 Obtain a 4TX ECU marked with and E
2 Remove and replace 5GG ECU
3 Remove speed sensor from the speedo assembly - tape up under the front fairing
4 Remove the odd relay from above the ECU unit (white with four wires)
5 Bridge output of relay with a fused link - we used 7.5 amp
6 Smile lots with what appears to be a full power bike with working lights
It appears the imports are restricted in two areas - speed sensor for the 180 kph restriction and a programming restriction in the ECU unit
this example also used UK spec clocks (rev, tacho, temp etc)
