Mk1 Fuel Pump Overhaul
8 replies to this topic
#1 Studley Ramrod
Posted 23 November 2009 - 05:25 pm
Thought I'd throw up some photos of the mk1 fuel pump in all it's technical splendour !
As you can see from this photo, the bolts are covered in crud. Needless to say they are also made of fudge and it's not too difficult to end up with a round slot instead of a crossed slot.
If you suspect fuel is getting into the vacuum side of the pump try loosening the six bolts half a turn, and then re-tighten them. Mine were loose.
Next job is to prise the smaller of the 2 cases away from the body. I used a pair of pliers and grabbed the vac. pipe connection and GENTLY persuaded it to lift away. Don't try sticking a screwdriver inbetween the casings as it'll bugger the diaphragm.
If this cover is full of fuel then chances are the diaphragm is holed or cracked. It's this fault that allows the fuel to get into the vacuum pipe and on into the cylinder.
The photo below is of the diaphragm, the colour is probably from the bolts rusting up. A close inspection of this diaphragm for holes or cracks revealed nothing....which is nice !
Same applies to splitting this larger casing, don't stick anything sharp between them. This black diaphragm fells more like a vinyl than a plastic and it feels bloody rubbery !
This is where all the sand and bits of grit gather, as you can probably see.
Again, inspect for holes/cracks.
Next thing to do is to clean all the parts, I wire brushed the bolts, then soaked in WD40, then brushed 'em again. A bit of washing up liquid and an old toothbrush to clean the other parts. The clear diaphragm had come away slightly at the edge and so I got a cotton bud or 2 and managed to delicately clean some of the crud off the inside.
Insert a cake break here :---
Next up (munch, munch) it'll be a reassembly (scoff, chomp) and a test jobby. (yummy, yummy)
( brush of hand to remove all the crumbs ! )
#2 dapleb
  • 18,387 posts
Posted 23 November 2009 - 05:31 pm
Thanks for sharin SR. Is there any point to dismantle SR if non of the diafragmers are available?
Anyone know if there is a diff atwix mkI and mkII pumps? Oi 'ave a mkII type to replace me old mkI wan. I DONT want an electrickery one.....quite happy following the KISS principle spank you.
#3 Studley Ramrod
Posted 23 November 2009 - 05:43 pm
Probably not Dappers ! hehe I'm actually checking this to see if it'll be ok. It's a spare and I didn't fancy fookin about fitting it only to find there's a big hole in there. I've just become aware that the mk1 and mk2 pumps are different ? Or are they ? I was hoping this pump could be put onto Mooses bike.
EDIT: Looking at the fiches the 2 are physically different and although they probably work the same, the shape means they probably won't bolt onto the 'other' model. Pooooo !
Edited by Studley Ramrod, 23 November 2009 - 05:48 pm.
#4 dapleb
  • 18,387 posts
Posted 23 November 2009 - 05:52 pm
Very useful to see what is in there as I intended havin a prod around in my ole wan. Shame that them 2 bits o rubber aint available! Wonder if the diafragmers are available under another guise.
#5 TonyDevil
Posted 23 November 2009 - 06:30 pm
yes mk1 and mk2 are diff
mk2a used a leccy pump
also TRX and XTZ are all different but interchangeable
#6 dapleb
  • 18,387 posts
Posted 23 November 2009 - 06:39 pm
QUOTE(dapleb @ Fri 15th May 2009, 02:57 PM) <{POST_SNAPBACK}>
Anyone know if mkII fuel pump is same as mkI?
QUOTE(TonyDevil @ Fri 15th May 2009, 03:28 PM) <{POST_SNAPBACK}>
mk2 yes
QUOTE(TonyDevil @ Mon 23rd Nov 2009, 06:30 PM) <{POST_SNAPBACK}>
#7 aytcat1
aytcat1
  • 1,093 posts
Posted 23 November 2009 - 06:46 pm
I had one similar to that on my Twin headlamp model 3AJ, 1989 XT600ZE Tenere,took that apart that was full of muck etc.
Think thats why yamaha have put the airfilters up top under tank so it dont collect the dust etc so easily.
#8 TonyDevil
Posted 23 November 2009 - 07:57 pm
QUOTE(dapleb @ Mon 23rd Nov 2009, 06:39 PM) <{POST_SNAPBACK}>
they are the same mounting and connections, just the case slightly different shape/size
the xtz and trx are same again, diff shape and size and same function
i've swapped em round soo many times i've lost track of which one is which
#9 dapleb
  • 18,387 posts
Posted 23 November 2009 - 08:11 pm
OK ta. so it'll fit on fine.
Might have a quick investigate for diafragmers first to see whats (not) available. I know for sure that old BMW diafragmers are still available so Shirley someone makes these things. Seems a huge sillyness to make such an elaborate and easy to rebuild part but not provide a little plastic bit!
