Crack Fairing
5 replies to this topic
#1 kmax
kmax
  • 161 posts
Posted 16 January 2010 - 06:57 pm
here in Singapore, most of 9ners with tall windshields have suffer from crack fairing, a friend spotted on mine and one after another the rest have discovered.
most of us are using Eagle Screen and due to high speed and wind resistance, the fairing is getting cracks... i am not sure yamaha original windscreen users would have this issue. it has to be fixed asap or else cracks will be longer and longer
start from stripping up the fairing. it's relatively easy job.. take out side panels, windshield, fairing around instrument panel, then there's 4 screws to secure the nose fairing (2 up, 2 below the instrument panel) detach pilot light and signal light sockets and off you go.
naked TDM.. (so ugly...)
here are the cracks
i use small pieces of metal grills to reinforce the fairing since i'll still be using tall windshield.
mark for cutting
superglued to make it stable
then apply epoxy to glue them together
so far so good, it's more firm and back to normal condition.. will try to go for speed test later
Edited by kmax, 17 January 2010 - 02:34 am.
#2 Matt101
Matt101
  • 2,391 posts
Posted 16 January 2010 - 08:02 pm
Thanks for the warning but that is one LARGE screen.
I have the largest Yamaha one on and it isn't even close
to that!!
Matt
#3 robelst
robelst
  • 1,844 posts
Posted 16 January 2010 - 09:51 pm
I'd rather take the bus before fitting a screen like that. Mind you, the bus is probably draftier than that laugh.gif
That was not a banana, Dougal
#4 Firestorm
Firestorm
  • 93 posts
Posted 17 January 2010 - 03:38 pm
QUOTE(robelst @ Sun 17th Jan 2010, 05:51 AM) <{POST_SNAPBACK}>
Kmax travel a lot with his ride, with a tall screen like this..... offered great protection from the rain &
'flying' debris stirred by the 4 wheelers.
Actually it look pretty good with the tinted version.
Edited by Firestorm, 17 January 2010 - 03:39 pm.
Nothing can compare a gd smooth ride out on my TDM
#5 Studley Ramrod
  • 19,356 posts
Posted 17 January 2010 - 04:31 pm
#6 wicklamulla
Posted 17 January 2010 - 07:17 pm
that screen is simply too big and lets face it, not really required. wonder if the 'Tiger' screen from Australia will suffer the same fate ?
