Oil Consumption
28 replies to this topic
#1 Finch
Finch
  • 81 posts
Posted 14 March 2010 - 04:30 pm
My 1996 mk2 has drunk over 1l of oil in 3500 miles. Does this seem excessive?
cheers
#2 Moose
    Master Cake Baker
  • 3,312 posts
Posted 14 March 2010 - 04:31 pm
QUOTE(Finch @ Sun 14th Mar 2010, 04:30 PM) <{POST_SNAPBACK}>
cheers
Not at all, many say 1/2 ltr every 1000 miles so ya doing ok fella
#3 robelst
robelst
  • 1,844 posts
Posted 14 March 2010 - 04:48 pm
It's "normal" for 850 TDMs, it doesn't seem to indicate excesice wear. Mine uses around a litre per 3,000 miles, just as it did 40k ago when I bought my 02 reg Mk2 (just over 60k now).
It wouldn't be too much of a worry if the difference between the min- and max level wasn't around a measily 400 ml (my own estimate with topping up while looking at the watch glass), which isn't much for a dry sump-setup with a nearly 4 litre capacity oil-tank.
That was not a banana, Dougal
#4 wicklamulla
Posted 15 March 2010 - 08:49 pm
cheers
thats excellent as i had a tdm that used 1ltr every 1000 miles and Mrs. Yamaha say thats perfickly normal.
#5 Finch
Finch
  • 81 posts
Posted 15 March 2010 - 08:54 pm
Was concerned as the bike sometimes seems a bit reeky when revved hard. Perhaps its just soot build up in the exhaust due to not being able to open it up to much over the winter?
#6 wicklamulla
Posted 15 March 2010 - 09:00 pm
QUOTE(Finch @ Mon 15th Mar 2010, 08:54 PM) <{POST_SNAPBACK}>
#7 TonyDevil
Posted 15 March 2010 - 10:55 pm
this has all been done before, but anyway....
anything between 1litre per 1000-4000miles is normal
it seems to be worse if you cruise at motorway speeds more often
difference between bottom and top of markers is 300-400ml on XTZs, all TDM850s and TRXs
#8 dablik
  • 10,882 posts
Posted 16 March 2010 - 10:02 am
QUOTE(TonyDevil @ Mon 15th Mar 2010, 10:55 PM) <{POST_SNAPBACK}>
Which leads me to ask then Tony, how often (miles) should i be checking Bigred on my upcoming adventure, motorway all the way to Luxembourg.
This is for a MK1 not a MK2 as per the post for those that dont know.
Cliff
#9 TonyDevil
Posted 16 March 2010 - 11:48 am
QUOTE(dablik @ Tue 16th Mar 2010, 10:02 AM) <{POST_SNAPBACK}>
Cliff
if you are doing a few hundred miles a day i'd check it each evening when you stop
#10 dapleb
  • 18,351 posts
Posted 16 March 2010 - 11:56 am
I aggrozzle make it a part of yer daily routine, once you get in the habit it becomes second nature.
#11 Trotski
Trotski
  • 535 posts
Posted 16 March 2010 - 01:40 pm
QUOTE(TonyDevil @ Tue 16th Mar 2010, 10:48 PM) <{POST_SNAPBACK}>
keep an eye on it, it'll sneak up on you and chew off your conrod bearings.(see my sig.)
Trotski
#12 Jana
Jana
  • 62 posts
Posted 16 March 2010 - 02:18 pm
QUOTE(dapleb @ Tue 16th Mar 2010, 12:56 PM) <{POST_SNAPBACK}>
I just bought a TDM. What is the easiest way to check the oil level without a main stand?
Can i use a rear paddock stand, or does it lift the back too much?
Is it really important that the motor is at running temperature ?
#13 tdm850rider
Posted 16 March 2010 - 02:33 pm
QUOTE(Jana @ Tue 16th Mar 2010, 10:18 AM) <{POST_SNAPBACK}>
That would probably depend on if it's a Mk1, Mk2/2a, or 9er.
On a Mk1 (3VD), just straddle it to hold it upright and check the dipstick.
#14 Jana
Jana
  • 62 posts
Posted 16 March 2010 - 02:39 pm
QUOTE(tdm850rider @ Tue 16th Mar 2010, 03:33 PM) <{POST_SNAPBACK}>
MK2, so no dipstick?
#15 TonyDevil
Posted 16 March 2010 - 03:06 pm
QUOTE(Jana @ Tue 16th Mar 2010, 02:39 PM) <{POST_SNAPBACK}>
nope, sight glass thats hard to see
#16 tdm850rider
Posted 16 March 2010 - 03:29 pm
QUOTE(Jana @ Tue 16th Mar 2010, 10:39 AM) <{POST_SNAPBACK}>
You could prop the side-stand with a bit of wood so your Mk2 is 'almost' upright. but I would try this:
Get a bud to hold the bike up straight, see where the oil falls in the sight-glass, then try the paddock stand and see if it falls in the same place (may be angled a bit). If they are very close then you can just use the paddock stand by yourself.
#17 dapleb
  • 18,351 posts
Posted 16 March 2010 - 04:21 pm
QUOTE(Jana @ Tue 16th Mar 2010, 02:18 PM) <{POST_SNAPBACK}>
Yes, really important.
#18 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 16 March 2010 - 08:11 pm
QUOTE(dablik @ Tue 16th Mar 2010, 11:02 AM) <{POST_SNAPBACK}>
Cliff
Touring Europe a couple of years ago with big motorway miles I was topping up every morning when I put petrol in, getting close to a litre a day. Take a bottle or something with a long nozzle to make topping up easy, I dribbled a lot of oil on forecourts until I found a flexi funnel at the Supermarche. rolleyes.gif
Assuming the oil goe's in the same place on a MK1...
#19 TonyDevil
Posted 16 March 2010 - 10:15 pm
i use castrol 4t GPS 10w40 and the 1ltr bottle has a helpful bendy nozzle that is perfect for topping up mk1&mk2 TDMs =)
#20 Finch
Finch
  • 81 posts
Posted 16 March 2010 - 10:18 pm
