* * * * - 1 votes
Mki Fork Dismantle Without Teflon Bush Annihilation
7 replies to this topic
#1 dapleb
  • 18,392 posts
Posted 15 March 2010 - 07:49 pm
Having discussed this with Robelst, it seems that this may only be relevant to the mkI…..or possibly to my own inability to use the slide hammer method effectively ;0). Would be interested if anyone with a mkII could take a pic the mkII bush setup please and thank you.
T’other day I found out the Bjorge oil fill method don’t always work! The seal just failed whilst under pressure and once leaking there was no way the pressure was going to be enough to budge the seal. I was in a hurry to fix one fork leg, did not have the time or money for new bushes so dug the seal out using a mixture of butchery and good fortune to get my bike bacon the road without dismantling the forks and destroying the lower Teflon bush…….Shirley theres a better way.
Of course if you are totally rebuilding your forks and know the bushes are shot then you may as well whack them to shreds with the Haynes method.
On to a different set of forks to test on…..the forks to dismantle had bushes with less than 1000miles on them. And since the bushes are so bloomin expensive it would be nice to retrieve them without chiselling the snot out of the Teflon using the Haynes/Workshop slide hammer type method, which I have NEVER been able to use and successfully save the Teflon lower bush.
The reason that the Haynes/Workshop method destroys the Teflon bush is because the upper bush is slotted and as it is knocked from its location it spreads more and allows the Teflon lower bush to slide underneath plus the shock of the slide hammer method and difficulty in pulling totally straight don’t help….well that’s my theory anyway.
Here’s how it went:
Remove all the guts, springs, damper rod, damper etc.. Parts of this are shown in the pootube clip. If in doubt ask ear on Carpe. It is ferry important you ain’t trying to pull the forks apart with the seal locating clip still in place or with the damper still attached to the fork lower…..that would NOT be good!
The next thing was to find safe places on the fork to pull on without causing any damage and without bending anything! The lower point was easy…..use the spindle hole. But the upper end was a tad trickier. I wanted something that could be easily recreated without the need for some jazzy fabricated/welded bracketry.
Loike dis:
Attached File  fork_pull.JPG   73.99KB   67 downloads
Remove the preload adjust section from the centre of the top bolt. Shove a decent grade bolt through the now empty centre. You will need a washer at the bottom to pull against and to protect the top bolt from damage, especially if you don’t have a spare!!!
Locating the bottom of the fork was easy peasy. Drill a hole in a plank of wood and whop a graded bolt through it with a washer to protect the spindle hole. You could also make a bush to protect the spindle hole.
Then extend the fork fully and drill another two holes to mount a bar/box section for the top bolt puller to go through.
Like dis:
Attached File  teflon_save2.JPG   69.34KB   61 downloads
I used box section for strength. The box section is spaced away from the plank so that the fork is free to “float” from the plank. Don’t want the pull to be uneven or any bending force at all. The hole drilled through the box section is to locate the puller.
So once your fork torture device is completed you can locate the fork.
Attached File  teflon_save3.JPG   40.31KB   64 downloads
Locate the puller bolt through the box section, put a washer on and start ratshitting.
Attached File  teflon_save4.JPG   57.44KB   53 downloads
Once the play is taken out of the setup and/or the seal starts moving you will either need to add washers or relocate the fork bottom (or both).
Attached File  teflon_save5.JPG   80.24KB   45 downloads
Hopefully you get as lucky as I did:
THAT’S THE BADGER
Attached File  teflon_save6.JPG   52.26KB   58 downloads
A 2 plank method would eliminate problems of the bolt moving in the plank but would require longer bolts and a lille more work
#2 wicklamulla
Posted 15 March 2010 - 08:03 pm
thas great, so it's basically similar to the slide mefod but you apply slow, gradual and even force instead and hey presto ? !
#3 dapleb
  • 18,392 posts
Posted 15 March 2010 - 08:05 pm
Yeah you butt (hrumph) the two bushes (chortle) against each other noice and level loike and then pull....not moving on and off each other. Tested on both fork legs now and worked twice...
EDIT: pootube in 34mins 52 seconds.....if interweb can last that long.
#4 Studley Ramrod
Posted 15 March 2010 - 08:24 pm
Jobs a gudgeon !
#5 dapleb
  • 18,392 posts
Posted 15 March 2010 - 08:29 pm
QUOTE(Studley Ramrod @ Mon 15th Mar 2010, 08:24 PM) <{POST_SNAPBACK}>
Lettuce just hold of.....might be its just my incompetence and everyone else is coping fine with this.
#6 dapleb
  • 18,392 posts
Posted 15 March 2010 - 09:05 pm
http://www.youtube.c...eb?feature=mhw4 smile.gif
#7 wicklamulla
Posted 15 March 2010 - 09:20 pm
yeah baby, MKI Fazer 600 forks (with no preload adjustment) suffer bush destruction in a similar manner and your jig method would prolly prevent this although you'd need to replace the fork top bolts with suitable bolts with holes thru them in order facilitate 'pullage'.
Edited by wicklamulla, 15 March 2010 - 09:23 pm.
#8 Studley Ramrod
Posted 11 July 2021 - 06:12 pm
Hmmm, might give this method a go.  I got my bro to weld me a frame for use on oil fill method but I reckon a bit of modding would make it useable for this method.  This method is a lot less messy too.
