Safety Bling
10 replies to this topic
#1 hammerman
hammerman
  • 705 posts
Posted 24 July 2010 - 07:20 pm
I saw these bikeviz bullets and it seemed like a good idea at a reasonable price
http://www.bikevis.com/
I made some brackets up to allow me to mount them on the back of the indicators
I've wired them up to the side light circuit adding a connector in case I need to disconnect them (maybe MOT ?). They pull very little current too (30mA / 1/3W per light).
They are very bright, brighter than the camera shows them
Not designed to light the road up, but should get me noticed in the traffic
Edited by hammerman, 24 July 2010 - 07:23 pm.
#2 dicky1
dicky1
  • 837 posts
Posted 24 July 2010 - 08:01 pm
They look good, might try some meself.
#3 dablik
Posted 24 July 2010 - 08:03 pm
Yep got them on already, white and corouk has the blue set, but now i've seen your pictures wish i had put them there as well, mine are on the fairing, defo help you to get seen.
#4 Matt101
Matt101
  • 2,391 posts
Posted 24 July 2010 - 08:10 pm
Got the T-Shirt. Very good investment.
Matt
#5 Robodene
Robodene
    Robodene
  • 1,547 posts
Posted 24 July 2010 - 09:17 pm
QUOTE(Matt101 @ Sat 24th Jul 2010, 09:10 PM) <{POST_SNAPBACK}>
I used domestic Osram Dot-it LCD units. Fixed them to my handguards (see avatar). I am fairly sure they make a difference to visibility.
#6 stu
stu
  • 2,060 posts
Posted 25 July 2010 - 03:05 pm
DO they go off when you turn on the indicators? If not, you are obscuring your own signals.
#7 Robodene
Robodene
    Robodene
  • 1,547 posts
Posted 25 July 2010 - 03:43 pm
QUOTE(stu @ Sun 25th Jul 2010, 04:05 PM) <{POST_SNAPBACK}>
They are on all the time. There is 235mm vertical separation, and 260 horizontal separation.
Do you think this is too close together?
Robo
#8 HonaTDM
HonaTDM
  • 205 posts
Posted 25 July 2010 - 04:12 pm
That's the problem with all bright lights, the tend to obscure everything else.
Just accept no-one in front will see you indicating (always a good policy because chances are they won't anyway).
#9 hammerman
hammerman
  • 705 posts
Posted 25 July 2010 - 06:11 pm
QUOTE(HonaTDM @ Sun 25th Jul 2010, 05:12 PM) <{POST_SNAPBACK}>
You can still see the indicators no problem, and at the end of the day where are the indicators on a car ? Right next to the headlights. But you are right no one will see them anyway.
#10 stu
stu
  • 2,060 posts
Posted 25 July 2010 - 07:04 pm
QUOTE(Robodene @ Sun 25th Jul 2010, 04:43 PM) <{POST_SNAPBACK}>
Robo
I meant Hammers ones, actually; they are closer than yours. Where did you get the LED units?
QUOTE(hammerman @ Sun 25th Jul 2010, 07:11 PM) <{POST_SNAPBACK}>
Well, the real danger with bike indicators is that the rider forgets to turn them off, and the emerging driver thinks they are turning in to the road he is exiting. Not seeing them when you ARE signalling prolly won't make much odds.
Car light design is shite. Look at some Passat rear clusters and the indicator is INSIDE the brake/tail light, very hard to see.
#11 Robodene
Robodene
    Robodene
  • 1,547 posts
Posted 25 July 2010 - 07:52 pm
QUOTE(stu @ Sun 25th Jul 2010, 08:04 PM) <{POST_SNAPBACK}>
I found mine on the internet searching for 'Osram DOT-it' (though others make them). They are AAA battery powered (a considerable advantage for me with non-existent electrical know-how) and come with a choice of fixing methods. I used the velcro. I had to make up mountings for fixing to the handgards with its all-sorts-of angles (mine in wood). My other bike has them higher up on the mirror stalks with a grub screw to secure placement. They are all aimed at the potentially recalcitrant driver at their 'T' junction on my left, on a straight road. I once read that research had identified that a triangle of lights increasing in size gave drivers the best means of judging a bike's approach speed....
