Clunk on braking
34 replies to this topic
#1 andyj
andyj
  • 611 posts
Posted 20 September 2006 - 08:02 am
Just (5-600 miles ago) had the bike services by a Yamaha dealer (Doug Dearden's, Holbury for anyone knowing the South Hants area). One of the things I asked him to make sure was done was ahead bearing check because I worried I had over/under-tightened them when I did it myself. Now on firm braking, if the front wheel hits a bump there's a solid clunk from the front end. I'm off for a week to mid-France next Friday so really have only this weekend to fix anything that's amiss.
Head bearings again or could it be something more insidious like some sort of bush within the forks themselves?
Also, and unrelated. I've only got a std. Mk7 scottoiler fitted. If I fill it up before leaving, is it likely to last a full week's nbike touring holiday or should I be looking to take extra to top it up? I might have the time to buy a lube-tube but I've overcooked the holiday costs so money's too tight.
Another boring night & I'm feeling pissed....
#2 duibhce Kaelann
duibhce Kaelann
  • 1,147 posts
Posted 20 September 2006 - 09:05 am
QUOTE(andyj @ Wed 20th Sep 2006, 09:47 AM) <{POST_SNAPBACK}>
the easiest way to check: if you have a centre stand use it and put some weight on the rear so the front wheel comes of the ground. Stand in front, grab the top section of the fork and wiggle it. If there is play it is most likely the bearings.
If there is no play repeat with the bottom section of the fork, if there is play it is most likely the fork.
if you don't have a centre stand find something else to get the front wheel of the ground.
Yamaha XJ600S Diversion '94
Yamaha XJ900S Diversion '97
Suzuki SV650S '01
Yamaha TDM900 '04
#3 Boštjan
Boštjan
  • 7 posts
Posted 16 April 2007 - 09:16 am
#4 TonyDevil
Posted 16 April 2007 - 10:21 am
a standard mk7 scotty will give you approx 500miles if set up for correct drip rate etc
a lube tube will increase the range to approx 2000miles
obviously wet weather will mean increased oil use
#5 andyj
andyj
  • 611 posts
Posted 16 April 2007 - 11:18 am
QUOTE(Toneski @ Mon 16th Apr 2007, 11:06 AM) <{POST_SNAPBACK}>
Unfortunately I like it wet & dripping. Made a Divvy 600 chain last 30k miles that way - and I'm not easy on the transmission, either.
#6 Boštjan
Boštjan
  • 7 posts
Posted 16 April 2007 - 11:45 am
I have the same problem. WHen i brake hard (on spot )not moving i hear a clunk and when i release back up, also.
I sit on the bike, press front brake and rock the bike front down an up. if i rock it to the limit, i hear clunk/clunk. It really concerns me, because the steering is really important, and i wouldn't like it to get stuck.
I have a picture of my steering and i am wondering if the gap i pointed out isn't to big but don't know how to post it in the reply.
The picture is here: http://www.email.si/...p.php?id=261655
Can anyone look on theirs and tell me if this is ok ?
Edited by Boštjan, 16 April 2007 - 12:18 pm.
#7 Drew48
Drew48
  • 1,150 posts
Posted 16 April 2007 - 03:11 pm
My mk2 did that but the mk1 doesn't- never got to the bottom of it either (no point to my post as it's no help whatsoever blink.gif )
CB125 SUPERDREAM, DR125, MZ125ETZ, CD200BENLY, CB250SUPERDREAM x 2, VT250F, XT350,SRX400,CX500EC,XT600,GPX600C1,TDM850MK2,GS850,TDM850MK1,XJ900F,SV1000S, SV1000N, TDM850MK1 (nr2), TDM850 MK1 (nr3),TDM850 MK1 (quatre)
#8 Guest_Emmett_*
Guest_Emmett_*
Posted 16 April 2007 - 05:59 pm
QUOTE(nhstedium @ Mon 16th Apr 2007, 03:56 PM) <{POST_SNAPBACK}>
My mk2 does it too, I haven't got a mk1, and I haven't got to the bottom of it either. unsure.gif
#9 wicklamulla
Posted 17 April 2007 - 07:46 pm
me tinks its just noisey fork internals.
#10 andyj
andyj
  • 611 posts
Posted 17 April 2007 - 09:04 pm
Just thought I'd point out this is an old thread recently rejuvenated.
I have also had the same thought as Wicky, because I'd had a Yambrahahahahaha mechanic tighten up the head. Twice. And it still occasionally clunks as I meet sleeping policemen (lazy bastard pigs!) or pot-holes.
I'm still vaguely concerned that the inner bushes are going/gone. At 24k miles. Not that impressive, if you ask me.
#11 Boštjan
Boštjan
  • 7 posts
Posted 18 April 2007 - 06:02 am
QUOTE(andyj @ Tue 17th Apr 2007, 10:49 PM) <{POST_SNAPBACK}>
Mine has 7000 km on the clock, so its even less impressive. Have an impresion, that the previous user has kissed something with the front.
What head did he tighten up ? Did anyone look at the picture and notice something odd ? I have a suspicion that the gap on the head is too big.
This is the link to the picture (can't paste paste the picture in here):
I hope you can see it. Can anyone check their bike if the gap is the same ?
#12 Guest_GuyGraham_*
Guest_GuyGraham_*
Posted 18 April 2007 - 05:15 pm
Yes - both of my TDM's forks have been clunkers
just live with it
As Wicky says, noisy internals
#13 dandywarhol
Posted 18 April 2007 - 05:30 pm
The gap looks ok Bostjan.....there is a rubber washer between the nuts.
#14 Cavey
Cavey
  • 572 posts
Posted 18 April 2007 - 06:28 pm
My 99er does it too. I seem to remember another thread some time ago, where somebody suggested tapping some nuts somewhere. I never did get round to doing it and now can't find the thread..... rolleyes.gif
It's good to know it's not just mine though as I originally thought the worst and imagined having to change the head bearings. I bought her with only 3k8 miles on and she did it then so I thought that maybe the previous owner had done a load of stoppies/wheelies etc.. unsure.gif
It's not having what you want, it's wanting what you've got.
#15 TonyDevil
Posted 18 April 2007 - 10:46 pm
QUOTE(Cavey @ Wed 18th Apr 2007, 07:13 PM) <{POST_SNAPBACK}>
head bearings need changing on my XTZ and thats only got 19,000kms on it blink.gif
#16 Boštjan
Boštjan
  • 7 posts
Posted 19 April 2007 - 08:13 am
QUOTE(Toneski @ Thu 19th Apr 2007, 12:31 AM) <{POST_SNAPBACK}>
Sorry, my english isn't very good.
What are "head bearings" (maybe you can paste a picture) ?
#17 Landy
Landy
  • 1,387 posts
Posted 19 April 2007 - 08:32 am
#18 Mitch
Mitch
  • 534 posts
Posted 19 April 2007 - 08:38 am
No 1 on the bottom of the frame in the picture is also 'head bearing'.
Honda SS50
Honda CG125
Honda 250 Super Drean
Honda 751F1
Honda CX500
Kawasaki Z750E
TDM 900
BMW K1200LT (2000)
Nothing to add, has it all. :)
Kawasaki Z750E (1981)
In bits. :huh:
#19 Boštjan
Boštjan
  • 7 posts
Posted 19 April 2007 - 10:16 am
QUOTE(avonne @ Thu 19th Apr 2007, 10:23 AM) <{POST_SNAPBACK}>
Where is this picture taken from. I can't find this on JBX pages, can I ?
#20 Landy
Landy
  • 1,387 posts
Posted 19 April 2007 - 10:55 am
It's from the downloads page "TDM900 2004 (5PS) Parts List"
