Wot Have I Got To Take Off
43 replies to this topic
#1 Blackpin
Blackpin
  • 82 posts
  • TDM model: 1994
Posted 02 October 2011 - 11:44 pm
I now find I have a cracked frame no probs I got a good Welder
But I have to take the engine out for him to do the job so wot is
the minimum take off to get it out " like the carburettors - oil tank
shocker - battry box - " I am going to wire the harness to the frame
and so on and so on.
john
Ride the Round Britain Rally this Summer.
#2 dapleb
  • 18,386 posts
Posted 03 October 2011 - 06:15 am
Oid gerra book and follow the destructions. Not a bad job at all.
Cracked on the vertical section some way above swingarm pivot and slightly to the inside? A few peeps have had a cwack there and probably a good few more who aint noticed. Would be interestin to see a pic.
Good luck with yer fix.
#3 Studley Ramrod
Posted 03 October 2011 - 09:23 am
I think the carbs can stay on if you remove the throttle cables at the throttle end and disconnect the fuel supply
Here's my lickle list for wot to tek orf
Seat.
Cowling & side panels.
Tank.
Airbox.
Battery & box.
Radiator & Plumbing.
The vac pipes where they connect to the inlet stubs.
Exhaust system.
Front sprocket cover/s.
Rear brake lever, mechanism & switch.
Rear wheel - to get the chain slack enough to slip over the output shaft.
Clutch cable and choke pull mechanism and idle adjuster doohickymebob.
Engine brackets.
Going off memory so please alow for middle-aged grey matter fuzzyness.
Basically, just keep undoin' stuff until you feel a heavy weight landing on your foot tongue.gif
Edited by Studley Ramrod, 03 October 2011 - 09:26 am.
#4 TonyDevil
Posted 03 October 2011 - 12:30 pm
i'd remove everything and take the oppurtunity to have the frame and other parts powder coated.....
#5 3vd
Posted 03 October 2011 - 03:39 pm
Anyone got a photo of this ere crack..... where should I look?
#6 Studley Ramrod
Posted 03 October 2011 - 03:48 pm
The chassis has sometimes the tendency to crack on the inside, near the gearbox sprocket location. The main cause seems to be a too high mechanical constraints due to excessive use of the machine.
• Years : 1991-1995.
• Check / Repair : check the inside of the frame, left hand side, near the axis of the swingarm. A crack at this location needs a repair by welding with no delay.
• Difficulty : rather difficult, the engine needs to be removed.
#7 TonyDevil
Posted 03 October 2011 - 03:57 pm
me neither, i've checked mine each time i've done an engine swap and its been fine hidden.gif
#8 Studley Ramrod
Posted 03 October 2011 - 04:05 pm
The frame certainly gets rusty on the inner parts and along the seams dry.gif
Gonna get mine painted this winter.........probably.
#9 sidestand
Posted 03 October 2011 - 09:18 pm
QUOTE(TonyDevil @ Mon 3rd Oct 2011, 04:57 PM) <{POST_SNAPBACK}>
#10 3vd
Posted 03 October 2011 - 09:35 pm
Cheers, I'll have a look in the morning.
#11 wtfover
wtfover
  • 32 posts
Posted 04 October 2011 - 03:23 am
When I bought my bike, there was a crack starting at the swingarm pivot (left side) and went to the 10 O'clock position for maybe 20mm long. After I pulled the engine I found another crack on the inside of the frame. That also started at the pivot hole but went for at least 100mm. I also pulled the oil tank off and MIG welded it all up before the motor rebuild was done. Did it all while the frame was upright, but I should have layed it on it's side. That would have been easier than vertical welding.
I'm guessing the last owner shouldn't have ridden the bike off road with his wife on the back......
#12 masterbrewer
Posted 04 October 2011 - 06:54 am
Are there any photos of what to look for?
Yeah ..................... I know it's a crack tongue.gif ........ but?
#13 Rallyist
Posted 04 October 2011 - 05:58 pm
QUOTE(maximuspetrolhead @ Mon 3rd Oct 2011, 04:39 PM) <{POST_SNAPBACK}>
Picture of my crack oooeerr
when stripped will post pictures as it gets stripped and rebuilt, I think it is down to resonance of the frame in that area all Mk1's I have ridden have vibration peaks at/around 3500 & 4500 rpm felt more prominently through the left hand footrest so with this in mind will be strengthening the frame in this area with a shaped piece of square section steel curved to follow the shape of the frame, will decide action when stripped.
#14 3vd
Posted 04 October 2011 - 08:13 pm
#15 masterbrewer
Posted 04 October 2011 - 09:20 pm
Thanks for the photo.
Re resonance, I used to have a 250cc single cylinder superKart and all those models were renown for cracking frames, welds & undoing lock nuts. Bit of a worry when you're racing down the track @ 100mph blink.gif
#16 dapleb
  • 18,386 posts
Posted 04 October 2011 - 09:24 pm
The ones I have seen run up the inside of the frame by the seam, in the same rough location.
#17 wicklamulla
Posted 04 October 2011 - 09:35 pm
too many wheelies could account fer frame cracks too me tinks.
#18 Blackpin
Blackpin
  • 82 posts
  • TDM model: 1994
Posted 04 October 2011 - 11:28 pm
My crack is in the same place as Ralyist crack but going more up wards, will
get my photo up tomorrow,and a follow up with how the work went on.
My crack was hard to see after finding it I cleaned it back to the steel then I
put 5 coats primmer on it did 50 miles on the bike and you could see it very clear then.
Thanks for the offer studlel i thing i could be needing a the help on the rebuild.
Sorry for being a bit slow in replying to all this help off the site its very nice of you all, as
I just had to make a trip to Levant in Cornwall then stop off in Bridgnorth on the way back
that trip went very well on a bit boring roads .
jd
#19 wtfover
wtfover
  • 32 posts
Posted 05 October 2011 - 04:08 am
QUOTE(Rallyist @ Tue 4th Oct 2011, 10:58 AM) <{POST_SNAPBACK}>
Actually, that's right where mine started and not down by the pivot bolt area. Then it went around the front edge to the back side and upwards. Repair is holding up well after 10K (road) miles.
QUOTE(masterbrewer @ Mon 3rd Oct 2011, 11:54 PM) <{POST_SNAPBACK}>
I've seen plenty of your ride reports on ADVrider. Why your frame isn't cracked yet......
Just kidding. But you might want to simply use a flashlight and look your entire frame over just as a precaution.
Edited by wtfover, 05 October 2011 - 04:18 am.
#20 Studley Ramrod
Posted 05 October 2011 - 09:42 am
QUOTE(Blackpin @ Wed 5th Oct 2011, 12:28 AM) <{POST_SNAPBACK}>
jd
Not a problem bod smile.gif So long as it's before December when my transport will once again be in many, many pieces.
