1991 Tdm 850 Mk1 Project By Margus
177 replies to this topic
#1 Margus
Margus
  • 133 posts
Posted 21 November 2011 - 03:04 pm
Hy. First of all I'm sorry for some English grammar and vocabluary mistakes I make, English isn't my 1'st language.
I excanged my 1999 Cagiva Canyon 600 to a TDM 850 MK1 about a month ago and already have big plans with it.
Bike looked like this, when I bought it:
I've already taken the bike apart and work begins.
Things need to be done:
-Fork oil change and I'm also applaying protective rubber boots for the forks. -Done
-Repaint the bike to red or green (have'nt decided yet..).
-Sandblast and repaint the engine -Done
-Sandblast and repaint frame and swingarm. -Done
-Repaint rims. -Done
-Regrease ALL the bearings -Done
-Syncronise carburetors.
-Adjust valve clearances -Done
-Fit the engine with oil preassure switch.
-Repair my faulti RPM gauge.
-Fit handguards.
-Check carburetors -Done
-Check thermostat. -Done
-Mount a CLS 200µ chain lube system on my bike.
-Clean and check ALL the electrical connections.
-Make my side stand a bit better (longer and larger supporting plate for it). -Done
-Make a custon gear indicator.
-Make custom exhaust system out of Suzuki SV650 exhaust.
In the end my bike should look something like that:
Or like that:
Edited by Margus, 12 February 2012 - 08:28 am.
Work on my bike hasn't ended jet!
#2 dapleb
  • 18,379 posts
Posted 21 November 2011 - 03:15 pm
Nice one margus, unlike mine, your English is not going to be a problem.
We have a few Estonian members.
Enjoy the project.
#3 Matlock
Posted 21 November 2011 - 03:44 pm
QUOTE(dapleb @ Mon 21st Nov 2011, 03:15 PM) <{POST_SNAPBACK}>
Welcome margus.
#4 Studley Ramrod
Posted 21 November 2011 - 04:58 pm
welcome.gif to da club Marcus !
#5 Margus
Margus
  • 133 posts
Posted 21 November 2011 - 07:18 pm
Giving you an update already:
Right now my bike looks like this:
I'm gonna have a lot of job with this welded sprocket nut. I need to get it off, rethread the shaft and make a new nut with lathe (luckely I have a lathe in my garage)
#6 dapleb
  • 18,379 posts
Posted 21 November 2011 - 07:43 pm
loctite 638 will probably help from that happening again. Will be interesting to know how you get on saving that output shaft.
#7 aircooled68
Posted 21 November 2011 - 07:58 pm
#8 ChrisG
Posted 21 November 2011 - 08:11 pm
QUOTE(Margus @ Mon 21st Nov 2011, 03:04 PM) <{POST_SNAPBACK}>
Check the metal just in front of the stand that the stand pushes against when it's down, this can wear and means the stand moves further forward and the bike leans over more. Mine had a fairly large groove in the metal, a bit of work with a welder and a grinder to build it back up would have a similar effect to lengthening the stand. The jaws at the top of the stand where it bolts to the frame can also open out a bit, causing a looser fit and again more lean angle, so clamping them up a bit more can improve things.
Good luck with the project.
#9 dablik
  • 10,892 posts
Posted 22 November 2011 - 10:40 am
[quote name='Margus' date='Mon 21st Nov 2011, 03:04 PM' post='226338']
wub.gif wub.gif wub.gif Bigred, it's Bigred
#10 sidestand
Posted 22 November 2011 - 10:57 am
Edited by sidestand, 22 November 2011 - 10:59 am.
#11 dapleb
  • 18,379 posts
Posted 22 November 2011 - 11:28 am
QUOTE(dablik @ Tue 22nd Nov 2011, 10:40 AM) <{POST_SNAPBACK}>
it's Bigred
#12 wicklamulla
Posted 22 November 2011 - 01:53 pm
#13 aircooled68
Posted 22 November 2011 - 02:31 pm
QUOTE(wicklamulla @ Tue 22nd Nov 2011, 01:53 PM) <{POST_SNAPBACK}>
#14 Blackpin
Blackpin
  • 82 posts
  • TDM model: 1994
Posted 22 November 2011 - 10:09 pm
Ride the Round Britain Rally this Summer.
#15 Margus
Margus
  • 133 posts
Posted 23 November 2011 - 12:04 pm
Could somebody explain to me what Bigred, hammerite (is it a paint?) and crack in the frame mean in fhis forum. Some inside jokes?
#16 dmmsta
dmmsta
  • 3,627 posts
Posted 23 November 2011 - 12:13 pm
QUOTE(Margus @ Wed 23rd Nov 2011, 12:04 PM) <{POST_SNAPBACK}>
Bigred is the Red 850 you pictured as your "end goal" - I THINK
Hammerite is paint, which I think Tony (original owner of Bigred) used to coat most of Bigred (with the expection of the panels).
Crack int he frame - not sure...
Someone will be along to give a potted history of Bigred shortly I would expect wink.gif
Edited by dmmsta, 23 November 2011 - 12:17 pm.
#17 Studley Ramrod
Posted 23 November 2011 - 02:39 pm
Yes, Big Red does have a potted history biggrin.gif but I know sweet fa about it, however..............
The mk1 has a fault that causes the frame to crack. Despite knowing this for years, very few have actually been discovered, until a few months ago when 2 appeared almost simultaneously rolleyes.gif
http://www.carpe-tdm...o...25&hl=crack
Worth checking out whilst you can !
#18 Kalts
Kalts
  • 104 posts
Posted 23 November 2011 - 07:22 pm
Hey-ho Margus, your list would be incomplete without bluespots.. these are newer and much improved front brake calipers.
#19 Margus
Margus
  • 133 posts
Posted 23 November 2011 - 08:10 pm
QUOTE(Kalts @ Wed 23rd Nov 2011, 09:22 PM) <{POST_SNAPBACK}>
Maybe later, but not this winter. As a student I dont have much money to spend.
#20 Margus
Margus
  • 133 posts
Posted 25 November 2011 - 07:53 pm
On this screen I will be able to see my oil temberature
And a led will show me what gear I'm at (currently at 4'th gear)
