Another Hid Thread...
Posted 21 March 2012 - 01:49 PM
So what about the one HIDS4U ? If so, which bulb, 5000k, 6000k or 8000k? and Projector H7 or Reflector H7R?
I think I will do the dipped beam only for the time being anyway as it's to be seen to necessarily to see where I'm going.
What does the panel think?
Nick
Posted 21 March 2012 - 02:07 PM
For that price you can get a car set, and either HID both dipped & main beam, or go halves with someone.
I wouldn't go above 6000K. I've run 4300K, 5000K and 6000K. The 43's are a good white light with touch of yellow, 50's are a solid white, 60's have a touch of blue to them. Personally it would be 5000K next time I get any.
As for bulbs, you should get H7R, as these have an extra reflector on the bulb to account for "Reflector" type light units (H7 HIDs should be used with Projector type lights).
Check eBay...something like THIS
You'll also need a blub holder...I used one of THESE (isn't where I got them from, but same part)
Thinking about it, if you want to go halves let me know...I'm just south of Maidstone, and commute daily to Docklands (M20 / A20) so we seem to be in the same neck of the wood...
Edited by dmmsta, 21 March 2012 - 02:11 PM.
Want:
- Tank Cover
- New Seat
- New
BikeTDM
- Laser Duo Tech Pipes
- Fender Extenda (finally)
- DL650 Hand Guards
- Air-Box Mod (Thanks JBX)
- H7R HID conversion (Thanks Stu)
- MRA Double Bubble screen
- BikeVis CREE Running Lights - Pening fitting
- Renthal's - Street Fighters + Bar Risers to get the Hand Guards to clear the fairing
- Symtec Heated Grips
- Touring ScottOiler - (Thanks Mad Dog)
Posted 21 March 2012 - 03:05 PM
Posted 21 March 2012 - 03:52 PM
Edited by TDMTAM, 21 March 2012 - 03:53 PM.
Posted 21 March 2012 - 06:33 PM
Cats
Edited by Cats, 21 March 2012 - 06:34 PM.
Posted 22 March 2012 - 12:22 PM
dmmsta ta for the offer but I wanted to move quickly on this...
Nick
Posted 22 March 2012 - 01:02 PM
Nick
Did you go for the H7R kit?
Posted 22 March 2012 - 01:07 PM
Posted 22 March 2012 - 01:17 PM
They say that, but they don't know the TDM like we do
When you remove the STD Halogen bulb you'll see the adapter thats fitted to that (may already know what I mean if removed bulb(s) before).
The HID bulb won't(can't) attach to that.
I started off by using some dense foam cut to shape to pack the gap between the back of the bulb, and the wire retaining clip, then moved to the adapter I've linked above.
The foam works ok, but the adapter is better.
Isn't a show stopper, but you will need something in there to hold the bulb tight against the headlamp otherwise it'll waggle around, and you'll end up damaging the bulb.
See the paragraph just above the 10th photo in THIS THREAD - gives you a better idea of what I'm trying to explain.
Edited by dmmsta, 22 March 2012 - 01:20 PM.
Want:
- Tank Cover
- New Seat
- New
BikeTDM
- DL650 Hand Guards
Posted 22 March 2012 - 04:14 PM
Where are you in NW Kent fella - I'm in Edenbridge and I have one of the bulb holders spare, it's all yours if you want to pop round and pick it up
Edited by hallrob1, 22 March 2012 - 06:01 PM.
1999 Gilera Runner 125SP, 2002 Piaggio X9 250, 2004 Bandit 600, 2005 TDM 900, 2007 Honda CB1300S, 1996 Triumph Sprint 900.2008 Tiger 1050,
Farkles:- Laser Duo Techs, Power Commander and custom map, Tenere 1200 Handguards, Yamaha Heated Grips, MRA Vario screen, SW Motech AluRack, Givi Pannier racks, Givi Maxia E55 & E21s, Garmin Zumo 550, Scottoiler, Hagon progressive Springs (front), Ohlins spring (Fat Bastard rating) on refurbed Shock.
Posted 22 March 2012 - 06:19 PM
What he said.
I used the bit if HD foam that came with the HID lamp, but later changed to the plastic hold like above.
Posted 22 March 2012 - 07:00 PM
Nick
Edited by OldGit, 22 March 2012 - 07:14 PM.
Posted 22 March 2012 - 07:58 PM
Nick
Saturday's fine with me - I'll PM my address
Posted 24 March 2012 - 04:25 PM
Not sure if will reside there permanently.
Will comment on performance etc later.
Also finished fitting a Stebel Nautilus
By feck it's feckin loud....
Posted 25 March 2012 - 02:44 PM
Have reverted to standard bulb for now. Fuse does not blow btw.
Anyone know what's wrong? Anyone had similar problems?
Ta
Nick
Edited by OldGit, 25 March 2012 - 02:45 PM.
#16
Posted 25 March 2012 - 02:50 PM
#17
Posted 25 March 2012 - 03:41 PM
Cats
Cats, looking at the picture - what is that black rectangular thing attached to the lower edge of your left mirror?
Danresh
TDM900 (2009) - Lowered suspension, Lowered side-stand with wider tip, O2 sensor removed, Givi top and side-cases, H-7+90% headlights, Additional blinking backlights, Stehbel horn, Secdem screen, BMW1150 Bar-risers, Remote controled cellular alarm sys, Throttle lock cruise control, CrumpBuster, GIpro-x type Gear Indicator, Mirrors raised up and out. Rear sprocket-46 teeth. Speedo Healer. K&N AirFilter. Barkbusters Storm Hand-Guards. Dobeck Performance TFI-1025 injection control. Skene Design P3 back LED lights. G-2 Throttle Tamer.
#18
Posted 25 March 2012 - 05:53 PM
Agree with moving the ballast to the other side of the fairing. ECU won't like it at all. I had 2 ballasts back to back in the other side and had no problems at all.
08' TDM 900 A R.I.P, 04 FJR1300 A Oh yes!!!!
#19
Posted 25 March 2012 - 06:33 PM
#20
Posted 25 March 2012 - 07:59 PM
I have 2. stacked.
