TPS Diagnostic Mode
11 replies to this topic
#1 SteveGlover
SteveGlover
  • 857 posts
Posted 18 November 2006 - 10:21 am
With all the talk about recalls for the TPS I thought this might be interesting. You can use the Diagnostic mode of the clocks to check the operation and adjustment of the TPS.
1. With the ignigition off, press and hold the SELECT and RESET buttons.
2. Turn the ignition on and hold the buttons in for 8 seconds until the display changes to read "DIAG".
3. Release the buttons.
4. Press and hold SELECT and RESET for 2 seconds.
The display will read "d01: XXX"
XXX is a value between 0 and 100. As you twist the throttle you will see this figure change.
XXX represents the percentage of TPS movement, and its approximately equal to the angle of movement of the throttle in degrees.
The manual specifies values for '02 to '04 models as follows:
Throttle Closed: 15 to 17
Throttle Fully Open: 97 to 100.
My TDM reads 16 closed and 99 open.
If your closed and open reading are out of spec then you need to adjust the TPS so they are in spec. You can probably use these reading to adjust the TPS, although Yamaha recommend a different method.
To check the TPS, very slowly rotate the twistgrip so you can see the nubers count up, 16, 17, 18, etc. If the numbers don't change smoothly, or if they suddenly drop or jump, then you've got problem with the TPS.
This test DOES NOT prove beyond doubt that the TPS is OK. The TPS has to operate in a smooth way with the vibration from the engine and bumps from the road, but thats difficult to reproduce in the garage. You could try holding the throttle to a certain point (1/4 open, 1/3 open, etc) and tap the TPS while checking that the reading doesn't jump.
#2 cyco900
cyco900
  • 269 posts
Posted 18 November 2006 - 10:31 am
drinks.gif Now thats interesting. As my bike is currently unride-able and I cannot get it to my dealer yet it gives me a chance to check the TPS. Thanx for that. banana.gif
Edited by cyco900, 18 November 2006 - 10:32 am.
Boring Old Fartz mcc / Diflas Hen Rhech - the PARTY club
[b]Now 03 TDM900 and Honda 450 Cafe Racer - previous bikes:- 97 virago535 -Triumph Trophy900- TDM850Mk1- Honda VF750F- Honda CB350K4- Honda CB650F chop- Suzuki 100- Honda CB900F x2 -Honda CB250 Dream -Kawasaki K400 -Honda CB650F Chop- Honda CB750K2- Kawasaki Z1000- HD Sportster1000- Triumph 500t- Honda 400/4- TriBsa 650- BSA C15- Triumph Speedtwin combo -BSA B33 chop- BSA A65 -BSA A10 chop- Ariel Golden Arrow- BSA Bantam- Francis Barnet- NSU Quickly. think thats the lot?
(\__/)
(")_(")
bunny hoppin
Sign by Dealighted - Coupons & Discount Shopping
#3 dandywarhol
Posted 18 November 2006 - 06:33 pm
Mine was checked by the Carrick Motorcycles (your fave place nhstedium blink.gif ) mechanic when he replaced the TPS - mine is out of range at the top end.....94 - he gave me another throttle body assembly to try which he had under the bench.
Edited by dandywarhol, 18 November 2006 - 06:34 pm.
#4 laughin in a windstorm
  • 862 posts
Posted 19 November 2006 - 07:40 am
this a good test, I'll try it good.gif , is the throttle turning bit done with the engine running or not running.
I saw a lot of people walking past a shop yesterday and they were all saying 'ahh' as they went by, then I realised it was a sweet shop rolleyes.gif , does anyone know if the dealers change items on recall if the bike has been modified.
#5 SteveGlover
SteveGlover
  • 857 posts
Posted 19 November 2006 - 10:21 am
QUOTE(laughin in a windstorm @ Sun 19th Nov 2006, 07:25 AM) <{POST_SNAPBACK}>
Not running or you'd rev the b*alls off it.
Can't see why not. If you're talking about the TPS then Yamaha know its possibly faulty so should replace it anyhow.
#6 Mick
Mick
  • 94 posts
Posted 20 November 2006 - 10:47 am
Laffin,
I do not know how much it helps but in Australia I had a new TPS fitted at no charge to my TDM that has been modified with a set of staintune pipes, a scottoiler and JBX's air box flap mod.
No problems with the dealer and I am the third owner. I did not receive a letter from Yamaha. I phoned up and told the dealer about the recall and they checked and booked my bike in.
My bike had stalled a few times so I thought the TPS could be sus.
Mick
#7 SteveGlover
SteveGlover
  • 857 posts
Posted 20 November 2006 - 12:15 pm
QUOTE(SteveGlover @ Sun 19th Nov 2006, 10:06 AM) <{POST_SNAPBACK}>
Engine won't start in DIAG mode anyway.
#8 laughin in a windstorm
  • 862 posts
Posted 20 November 2006 - 12:20 pm
QUOTE(Mick @ Mon 20th Nov 2006, 10:32 AM) <{POST_SNAPBACK}>
Laffin,
Mick
thanks, but mine is a little bit more modified than that, in the UK most dealers are not interested in anything....... erm.... different.
#9 duibhce Kaelann
duibhce Kaelann
  • 1,147 posts
Posted 20 November 2006 - 01:33 pm
QUOTE(laughin in a windstorm @ Mon 20th Nov 2006, 01:05 PM) <{POST_SNAPBACK}>
imho it's quite simple: yamaha sold you a bike with a faulty TPS. They admitted their mistake and have taken the correct measures to have them replaced. As long as you haven't messed about with the faulty TPS yourself, you are entitled to a new one. If your dealer makes a problem of it, find another one or contact Yamaha UK...
Yamaha XJ600S Diversion '94
Yamaha XJ900S Diversion '97
Suzuki SV650S '01
Yamaha TDM900 '04
#10 Guest_E.T._*
Guest_E.T._*
Posted 20 November 2006 - 01:52 pm
QUOTE(laughin in a windstorm @ Mon 20th Nov 2006, 12:05 PM) <{POST_SNAPBACK}>
I think there would be no problem at all - You haven't modified the engine have you? (airflap / plugs etc excepted) - even if you have I still don't think it should be a problem. Let us know if it is and we'll organise a protest ride or something! good.gif
#11 wicklamulla
Posted 20 November 2006 - 06:43 pm
QUOTE(E.T. @ Mon 20th Nov 2006, 01:37 PM) <{POST_SNAPBACK}>
orya cud get yer wife to lash off wan of those stern letters to MR. Yamaha UK again tongue.gif laugh.gif
#12 Hartside Man
Posted 21 November 2006 - 10:59 pm
mine reads 15 off and 98 full on
