Handgaurds For Renthal Bars.
11 replies to this topic
#1 Chris B
Chris B
  • 828 posts
Posted 24 April 2012 - 01:37 pm
I know there are 10000's of thread but I have been through the knowledge base and found nothing specific to Renthals, I'm getting a new set for my Triumph (ultra Low) so my 'Superbike mediums' are going on the TDM. Just wondered if any 9er owners with Renthals fitted have handgaurds and what they used.
Chris
02 TDM 900, Silver. 85k miles
#2 Moose
    Master Cake Baker
  • 3,312 posts
Posted 24 April 2012 - 02:34 pm
I did, no problems at all unless you wanna use OEM bar ends, or any that screw in in fact, you will need to tap the bars to fit the ends
#3 trevini
trevini
  • 1,881 posts
Posted 24 April 2012 - 02:40 pm
Or you can do what I did and use Motrax crash protectors. I'll post a pic later when I get on a pc and not the phone.
#4 Chris B
Chris B
  • 828 posts
Posted 24 April 2012 - 03:54 pm
QUOTE(Moose @ Tue 24th Apr 2012, 04:34 PM) <{POST_SNAPBACK}>
Is that Super Tennere guards? Where from and how much? Also do they interfere with the clutch at all?
#5 Moose
    Master Cake Baker
  • 3,312 posts
Posted 24 April 2012 - 05:15 pm
I fitted DL650 ones and had to tap the bars for the bar ends that had to be machined as in knowledgebase, IMHO Ugly but very secure and effective.
I then fitted the S10 ones, the bar ends had to be drilled and tapped by monsieur Henty, then they fitted just fine. IMHO better looking than the Suzuki ones bar far less effective but still good to use
#6 catsbum
Posted 24 April 2012 - 05:16 pm
KTM for Whitey. Very Solid, around £45
#7 trevini
trevini
  • 1,881 posts
Posted 24 April 2012 - 06:51 pm
Here you go....
#8 Daveb
Daveb
  • 1,907 posts
Posted 24 April 2012 - 07:29 pm
i used polisport bush guards with Renthals, no mods required as they fit into the end of the bars, and also have fixing clamps which i had to extend with a bit of steel
although trevini's looks better
2007 Triumph Tiger 955i
#9 trevini
trevini
  • 1,881 posts
Posted 24 April 2012 - 08:50 pm
Same principle - expanding bolt to hold the bar ends on
#10 Chris B
Chris B
  • 828 posts
Posted 25 April 2012 - 10:50 am
QUOTE(Moose @ Tue 24th Apr 2012, 07:15 PM) <{POST_SNAPBACK}>
Cheers, I'll stick with the DL gaurds then, function over form and all that. tongue.gif I just need to fine someone to borrow a tap off. laugh.gif
Re the Polisport guards, the purpose of mine is to keep the wind off my hands!
Re the Motrax ones do they add much vibration?
Edited by Chris B, 25 April 2012 - 10:52 am.
#11 Moose
    Master Cake Baker
  • 3,312 posts
Posted 25 April 2012 - 04:39 pm
#12 leehenty
  • 5,301 posts
Posted 25 April 2012 - 05:10 pm
These bar ends are best done in the lathe, makes for a very accurate job, and keeps the thread properly concentric in the bar end. For 8mm thread drill 6.8mm hole.
I would only advise HSS taps as carbon steel ones are crap.
This guy is a good egg for taps and dies mainly german stuff.
http://www.max-t.co.uk/tapsDies.html
you want metric coarse M8 x 1.25 pitch. Best buy a 'second' tap as a good all rounder if just buying one, as you can't start a bottoming tap in the hole.
If you are still stuck or unsure, pop em post to me I'll do 'em for you, post em back.
Edited by leehenty, 25 April 2012 - 05:16 pm.
