Posted 15 October 2012 - 04:05 pm
Can anyone recommend a good heat gun for use with heat shrink sleeving, typical use on bike electrics and similar, with the nice little nozzle adaptors and heat shield(s) to make life easy? Won't be used a lot but don't want it to fall apart either.
Posted 15 October 2012 - 04:32 pm
Posted 15 October 2012 - 04:57 pm
I carry a torch with me on the road. Basically, a cigar lighter will do it.
2010 BMW R1200GSA 30th Anniv
2006 BMW K1200S set up for touring
1992 TDM850 set up for touring
Posted 15 October 2012 - 05:03 pm
It's still working two years after I bought it.
Edited by hammerman, 15 October 2012 - 05:03 pm.
Posted 15 October 2012 - 05:06 pm
it is similar to this http://uk.rs-online....-irons/4335978/
Edited by Pantboy, 15 October 2012 - 05:09 pm.
Posted 15 October 2012 - 05:19 pm
If you already have one just use a decorators heat gun. I'm in the electrical industry and have used one of these many times for HS sleeving and for home use that's all I have. Don't put the head too close to the work area and keep the gun moving so that the heat does not get concentrated on any one spot, if you're really concerned about burning surrounding items you can mask off with kitchen foil ....
Posted 15 October 2012 - 05:50 pm
Posted 15 October 2012 - 06:13 pm
Sorted and on the Road Mick
Posted 15 October 2012 - 08:54 pm
1996 TDM850 in Yellow, Motad Nexxus, MK1 bashplate, Acerbis handguards, K&N, Xenons, Aux lamps, Bluespot calipers, Renthal 755 bars, DIY panniers, JBX-inspired gear indicator. (Sold 2025.)
- Look at Daniel's website, if you can be arsed.
- The mighty Hot Cold Ground, purveyors of quality blues. Featuring 2 Carpedians: Me- lead vocals/guitar: Trevini - guitar
- If you like my animated TDM avatar, nick it here:http://danielcarway....X-900-150px.gif. Full-size version: http://danielcarway....3VD-4TX-900.gif
Posted 15 October 2012 - 10:32 pm
I've never used anything other than the side of the soldering iron to do the shrinking.
So do I when I'm feeling lazy, but the hot air gun makes a very quick neat job of heat shrinking wiring. Particularly where you are using bigger / multiple wire heat shrink tube.
Posted 16 October 2012 - 01:05 am
'98 CT200P AutoAg ,
Posted 16 October 2012 - 03:30 am
Posted 16 October 2012 - 09:43 am
If not the above sugestions would be recomended.
Posted 16 October 2012 - 10:46 am
No need for fancy tools unless (as others have stated) you're going to be doing a large amount of work.
Also tagged with one or more of these keywords: Electrics
Start your Engine →
All About TDM →
Driving Me Ta Drink,Started by rustyscrew , 22 May 2016 |
Start your Engine →
All About TDM →
Tdm Fails On Road - ArghghghStarted by Sue , 05 May 2015 |
Start your Engine →
All About TDM →
Charging Problems.. Stumped..Started by Northpennines , 26 Dec 2014 |
