Any Tips On Removing Pistoons From 22Year Old Calipots?
60 replies to this topic
#1 dapleb
  • 18,376 posts
Posted 31 October 2012 - 04:08 pm
Decided to rebuild some calipots that have been lion aboot. Starting to wish I hadnt bothered now!
I borrowed some compressed air and mild heat and eventually managed to extend the pistons as far as they could make it without colliding, then split the calipers in half but even though all the pistons moved out as far as possible with compressed air, I cannot get enough purchase on the pistons to remove the buggers. I have mashed one piston trialling grips with a rag underneath and it didnt budge anyways.
Anyone got any good ideas on how to git them burgers oot? The only thing I can stink of at the mo is an interference fit with the inside of the piston and then pull loike a bassad,
Ugh.
#2 TinTin
TinTin
  • 1,296 posts
Posted 31 October 2012 - 05:11 pm
Its a long time ago since I did it but I got a grease nipple the same thread as the bleed nipple & pumped grease in it till it popped oot.
Mind you it was a single piston one but you could stop one of yours near the end of its travel with a g clamp or summit till the other is ready to pop out.
Air is compressable (obviously) liquids & grease arent.
Well it worked for me :P
Edited by yamahasam, 31 October 2012 - 05:13 pm.
#3 dapleb
  • 18,376 posts
Posted 31 October 2012 - 06:16 pm
Cheers Sam, I am kinda past that stage as they are all extended as far as possible without collision before the halves split. The Heinz suggested removing the seals from one side and then reinstalling the pistons and then repeating on the other side No idea how that could possibly work as you would have a non pressurisablesystem after removing the first seal!!!
I emailed the knowledgeable powerhouse on ebay who sold me the seals and they also sell pistons......phewww and suggested aluminium vice covers, the trouble is the calipot halves are a ridiculous near impossible to clamp shape.
I sure hope a previously working set of calipers are easier than this!!
EDIT: ahhh found an tool available for hollow pistons. Doubt it will cope with how stuck these are but cannae hurt none.
#4 Rallyist
Posted 31 October 2012 - 06:51 pm
Put em in the oven when nobody is looking, about Gas mark 8 230c/450f for about 20 mins and they will fall out :good: will stink a bit tho :badgerrock:
#5 dapleb
  • 18,376 posts
Posted 31 October 2012 - 07:07 pm
I didnt want to heat em up too much especially whilst split. Heat certainly helped with gettin the burgers to extend. Will defo try some more heat on me next attempt. ta.
#6 Studley Ramrod
Posted 01 November 2012 - 09:50 am
How about using some o that freeze spray on the pistoons ?
#7 dmmsta
dmmsta
  • 3,627 posts
Posted 01 November 2012 - 10:31 am
An "air duster" aerosol can will do the trick held up-sid-doodle.
Will need to be a cheap one tho, as the more expensive ones work either which way...
#8 dapleb
  • 18,376 posts
Posted 01 November 2012 - 01:31 pm
They have been monkey pissed to the max over the last few days, tried shock and unlock too but it werent a great shock that it didnt unlock. With the calipots split, you can feed spray in behind the pistoon easily too.....I got one out eventually and there is a good 20 years worth of crud in there, plus the seals have grown into the calipers!!! Keen not to damage the seal grooves I hoiked around unsuccessfully with a pencil but then picked up a blade fuse, nice wide contact patch in two areas, in and lever/flip and seals out in a second with no damage.
Now getting on with udder non calipot things until me new piston twirling tool arrives. I did read a neat trick with 2 tyre levers sandwiching a metal bar inside the hollow section to lever outwards and pull out piston.....clever idea.
#9 dapleb
  • 18,376 posts
Posted 02 November 2012 - 03:30 pm
Phew, that was ermm fun.
A few piccies of progress so far:
Starting point:
Attached File  calipot_start1.JPG   97.56KB   44 downloadsAttached File  calipot_start2.JPG   111.03KB   66 downloads
Jizerified and toothbrush scrub for a good while:
Attached File  calipot_jiz.JPG   98.39KB   68 downloads
Although still attached to hydraulics it wouldn't shift the pistons at all. Even with all others blocked off. So decided it was time to detach and try compressed air and heat which eventually got pistons extended as far as posible (but still rock solid in bores!).
Heat and compressed air FINALLY got me to ear:
Attached File  calipot_piston_extend.JPG   144.86KB   64 downloads
Next the calipot half bolts which were previously cracked open, were undone:
Attached File  calipot_splttin.JPG   133.11KB   59 downloads
Which left me ear:
Attached File  calipot_halves_pistonsin.JPG   114.37KB   66 downloads
Note the lille calipot half 'o'-rings. These were previously not available apparently but now powerhouse sell em as part of a kit on ebay.
After alot of swearing and a combination of heat gun, aluminium vice jaw covers AND a piston removal tool (could have done with an extra pair of hands for this really), oi gots to this stage:
Attached File  calipot_halves_pistonoot.JPG   92.36KB   70 downloads
Important to keep organised and luckily found a tray with right number of compartments:
Attached File  calipot_orgy_nised.JPG   97.89KB   64 downloads
Getting the seals out with a non scratchy instrument was not going well, kept snappin me pencil. These seals had grown in to the caliper so I picked up the nearest proddy thing (a fuse) and it worked first time. Just push in gently then lever upwards. Perfect and no damage to the seal recessesesesesseseesss:
Attached File  calipot_fusetrick.JPG   75.34KB   67 downloads
Next is clean of all the bits and inspection of pistons, I mullered one but the others should clean up ok. There is plenty of cleaning to do:
Attached File  calipot_manky.JPG   102.68KB   47 downloads
Also thinking of painting the outers, have some alloy wheel paint somewhere, not normally in to this painting lark so any advice welcome.
#10 tdm850rider
Posted 02 November 2012 - 03:33 pm
Perseverance pays.
#11 TinTin
TinTin
  • 1,296 posts
Posted 02 November 2012 - 03:52 pm
I painted some once. Bled brakes- paint off. :istupid: Stripped down again & polished the buggers. Kept em shiney for a while with solvol then just rubbed them with scotchbrite now & again to clean them & keep em looking nice. :good: Anodising is the only real option :badgerrock:
#12 stu
stu
  • 2,060 posts
Posted 02 November 2012 - 05:18 pm
So dappers, are you about to offer a reconditioning service ? :hide:
#13 dapleb
  • 18,376 posts
Posted 02 November 2012 - 05:28 pm
:lol: I wouldn't want to deprive everyone of the "pleasure".
Having said that you know oid do anything (well nearly) for you. If I survive a good testing of these then mayhaps. :)
The rebuild of calipers is not really very economical since a set of boo spots would probably work out the same as the rebuild kit. Of course they might need rebuilding too. I don't need or particularly loike the feel of boo spots, hence the choice of rebuild.
#14 Studley Ramrod
Posted 02 November 2012 - 09:53 pm
Coming to bits noicely ! :)
Was it a build up of crud that stopped the pistons coming out ?
Also, do ya reckon them o rings could be had without buying the kit ?
Godda spare set o calipots mesel, so might have a go at 'em :)
#15 dapleb
  • 18,376 posts
Posted 02 November 2012 - 10:08 pm
Yup I'm sure it was the 8 tons of crapola, the skank in the seals and being stored for years without moving that were stopping em comin ooot. This is a spare set, which if/when finished oil bung straight on the boike...at which point I will store the set that come off in DISMANTLED form until they are required. I wouldn't rebuild a set until you need em as the pistons sat still in the bores for long durations prolly aint no good ferrum.
I am sure you could get seals without the kit. Since I had collected one calipots worth of OEM seals over a year or so, powerhouse were kind enough to sell me one full kit and the calipot half o rings and bits n bobs only for t'other side.
Also on the trail of affordable replacement wubber hoses...will report bacon that wan.
#16 Matlock
Posted 03 November 2012 - 12:05 pm
The pistons seem in remarkably good nick considering the crudification and subsequent removal shennanigans.
#17 danceswithmopeds
danceswithmopeds
  • 2,425 posts
Posted 03 November 2012 - 08:40 pm
Any chance of a link to that Powerhouse place?
#18 dapleb
  • 18,376 posts
Posted 03 November 2012 - 09:00 pm
I have been getting stuff through ebay from em ear: http://stores.ebay.c...=p2047675.l2563
I have just ordered a coupla pistoons, if you want me to enquire about Carpe discount will happily give it a whirl. Either way, they have been pleasant and helpful peeps to deal with.
EDIT: If you donut see what ya want listed then send em a message and if they gots it they will put you up a listing.
#19 danceswithmopeds
danceswithmopeds
  • 2,425 posts
Posted 03 November 2012 - 11:09 pm
Thanks, stored for future use.
#20 dapleb
  • 18,376 posts
Posted 04 November 2012 - 06:56 pm
Me calipot halves are soaking in jollop at the moment and I have scrubbed with toothbrush but still some skanky bits in the seal grooves. Any good tips for cleaning in this confined area without scratching bits please and thank you?
