Rear wheel bearings
73 replies to this topic
#61 TimH
TimH
  • 182 posts
Posted 07 September 2010 - 11:05 pm
QUOTE(merlot @ Tue 7th Sep 2010, 06:13 PM) <{POST_SNAPBACK}>
so how many of each tim? my other bike has 3 bearings in the rear ohmy.gif and do you have seal info? cheers russ
Take the sprocket carrier off (also know as cush drive hub, also referred to as clutch hub in parts catalogue) and you'll have two 60/28 bearings, one each side of the wheel hub, and one 6206 in the sprocket carrier housing.
Exploded parts view
Sorry, don't have seal info, mine were ok so I reused them.
#62 wicklamulla
  • 11,965 posts
Posted 08 September 2010 - 12:06 am
i'd replace the seals as they are cheap and do wear.
#63 TimH
TimH
  • 182 posts
Posted 08 September 2010 - 02:29 am
QUOTE(wicklamulla @ Wed 8th Sep 2010, 10:06 AM) <{POST_SNAPBACK}>
yep, good advice...
#64 wicklamulla
  • 11,965 posts
Posted 08 September 2010 - 08:18 am
this i found out to my expense after replacing the sprocket carrier bearing and having to replace it again after only 8k !!!
#65 leehenty
  • 4,294 posts
Posted 05 October 2011 - 07:36 pm
for seals go here much cheaper than wemoto or bike specific stores, just be sure to measure your seals they usually have the size printed on them. sized by:
bore x outside dia x thickness.
http://stores.ebay.c...634Q2ec0Q2em322
#66 dapleb
  • 17,030 posts
Posted 05 October 2011 - 07:57 pm
Lee has also mlisted sizes here: http://www.carpe-tdm...o...c=23049&hl= good.gif
#67 Godzillamonster
Godzillamonster
  • 109 posts
Posted 03 January 2012 - 08:11 pm
Happy new year all,
My rear end felt somewhat squidgy this morning - and no, it wasn't due to the curry I ate last night..
Can someone please tell me the bearing numbers for a 3VD's rear whell & sprocket carrier?
Many thanks
20 months on the road riding overland from England to New Zealand on a '91 TDM850.
http://www.horizonsu...richardandlisa/
TDM round the world - YouTube
290 000 kms before gearbox blew, 190,000 on 2nd motor and still my daily wheelie commuter sports hack
#68 dapleb
  • 17,030 posts
Posted 03 January 2012 - 08:28 pm
Lee listed em ear: http://www.carpe-tdm...o...c=23049&hl=
If there are no replies to sprock carrier I can have anudder dig about....anything to keep the ole gal goin.
#69 dapleb
  • 17,030 posts
Posted 03 January 2012 - 08:48 pm
Ear ya go...courtesy of stinky:
QUOTE(Stink-Foot @ Fri 18th May 2007, 04:08 PM) <{POST_SNAPBACK}>
Correct number is 63/22 (id 22, od 56, w 16)
#70 Godzillamonster
Godzillamonster
  • 109 posts
Posted 03 January 2012 - 10:45 pm
Thanks - much appreciated.
Forgive my ignorance but Lees link appears to be for the oilseals on the bearing housing rather than the bearings themselves - or am I missing something?
#71 dapleb
  • 17,030 posts
Posted 03 January 2012 - 11:14 pm
QUOTE(Godzillamonster @ Tue 3rd Jan 2012, 10:45 PM) <{POST_SNAPBACK}>
Ooopsie. hows about these:
Front wheel 2 x 6303
Rear wheel 2 x 6203 (sprocket side) & 1 x 6303
#72 leehenty
  • 4,294 posts
Posted 04 January 2012 - 01:41 am
For 3VD,
Left bearing and middle bearings are the same, 17mm bore, 40mm outside dia, 12mm thick, 6203 2RS, so you need two.
Right wheel bearing is 17 bore, 47mm outside dia, 14mm thick. 6303 2RS.
Sprocket carrier is a 22mm bore, 56mm outside dia, 16mm thick, 63/22 with 2RS on the end for a double sealed one.
The / is very important here or you will order a massive 110mm inside diameter bearing which certainly won't fit and costs a fortune.
Sorry for the confusion. the page referred to by dappers is indeed oil seals.
Edited by leehenty, 04 January 2012 - 01:48 am.
#73 Godzillamonster
Godzillamonster
  • 109 posts
Posted 04 January 2012 - 03:22 am
Many thanks - much appreciated.
#74 treadman
treadman
  • 476 posts
Posted 07 May 2012 - 09:22 pm
changed allmine at 40.000mls , didnt need to cos they where all fine, just did for peace of mind for the next 40,000
Neil
