Test Video From Utube
Posted 01 January 2013 - 01:16 am
Posted 01 January 2013 - 10:09 am
Posted 01 January 2013 - 02:49 pm
If you go in to the Video Manager in Youtube and click on the video and then on Advanced settings below the video you'll get an option to allow embedding.
Done
Posted 01 January 2013 - 04:27 pm
Now you just need to find some more interesting roads
Posted 01 January 2013 - 10:09 pm
That did the trick
Got to drive miles for that, although the A25 from Dorking to Guildford has some nice bits.
Posted 02 January 2013 - 09:16 am
Posted 02 January 2013 - 10:58 am
What resolution do you use?
Where was it mounted?
What was the rattling noise?
Edited by drumwrecker, 02 January 2013 - 10:59 am.
Posted 02 January 2013 - 12:16 pm
Mounted it on the back of my left glove and got reasonable footage.
Worked out editing software and made a filum.
Now need to figure out how to make it public.
XT1200Z - Big and bouncy
GTR1400 - Chaufer the wife.
XT660Z - Fun and commute.
TDM900 - Yellow.
Posted 02 January 2013 - 12:29 pm
TDM900 - Yellow.
Posted 02 January 2013 - 01:40 pm
I understand it can use a 64gb SDxc and it does endless recording i.e overwrite when card is full.
Posted 02 January 2013 - 02:27 pm
Yes - although I opted for a 32GB card. that gives 5 hours at 720p60fps
not sure what the endless rec does yet, it says "allows you to record video with a fifteen minute time interval without stopping," I read that as a fifteen minute auto cut-off.
TDM900 - Yellow.
Posted 02 January 2013 - 02:47 pm
The overwrite facility does that as it is just a matter of using a small SD card.
The other option is tagging, the Drift HD Ghost has this and can be set to 5 minutes down to 30secs.. So if you have just been through a good bit of road or had an incident just hit the button and it back records the set time plus the present and future set time. Very handy. But it is £100 more than yours.
Posted 03 January 2013 - 12:51 am
http://www.aee.com/e...w.asp?Sendid=65
SWMBO got from Maplins
It records in 15 minute chunks of about 1.5Gb per chunk in 1080p HD, it will also output directly in HDMI, but I haven't tried that yet.
I reckon the battery will support about 3 hrs of filming.
The mounts, as supplied are a little wobbly, but I'm hoping a ram mount will sort that, the rattle is probably the clip on the strop I used as a secondary just in case the fecking thing fell off!
Or it might be the horn rattling around inside the fairing.
Posted 03 January 2013 - 09:39 am
If you're sprawled over the front of a black cab/white van/other stereotype after a SMIDSY incident, possibly the last thing in your mind at the time is to remember to hit the tag buttonI have been looking for a camera that will record "that incident".
Fuel Cans, Baglux tank cover, Givi E21 panniers, Givi Flow top box, Yamaha centre stand, Garmin Zumo SatNav,, Givi engine bars, Barkbuster S1 handguards, Powerbronze Fender Extender and Headlight guards.
Posted 03 January 2013 - 10:05 am
#16
Posted 03 January 2013 - 10:06 am
I think both of these facilities would be popular with cyclists as well as motorcyclists.
I don't understand why the manufacturers have not concentrated more on them.
I would rather have them than super duper slow motion for example.
#17
Posted 04 January 2013 - 10:06 am
Is it worth doing?
#18
Posted 04 January 2013 - 11:09 am
Jerry that is why the continuous or circular recording is a good thing as well.
There's loads of cameras for cars that do exactly that, but as you say not many weather proof ones around and cyclists and motorcyclists are more likely to need them.
I just acquired one of these for the car that's intended for exactly that purpose
http://www.prestigio...-RoadRunner-HD1
#19
Posted 19 January 2013 - 10:11 am
Test,,,
Edited by dablik, 19 January 2013 - 10:24 am.
Sorted and on the Road Mick
#20
Posted 19 January 2013 - 10:25 am
