Dear Mr Dapleb Sir...et Al Too
16 replies to this topic
#1 ElvisParsley
ElvisParsley
  • 58 posts
Posted 06 January 2013 - 04:42 pm
Hi all, weather's crap init?!
To my point; I've been spending some time over the olidees re-assembling my 'spare' 3VD to while away the time that should be spent doing something productive...apparently!! Whilst cobbling the parts back together, to hopefully resemble a motorcycle, I've decided to do the airbox rubber mod that Mr Dapleb pioneered some time ago. I can't bare just plonking the airbox back on again. Please could you tell me where I can get hold of the silicone hose to do the job? Not had much luck so far.
The amass of parts will be for sale soon if anyone is interested. Not pretty but it'll be cheap and the motor is peachy. Would make a great winter bike/engine donor/boat anchor etc...
Anyhoo, I'd like to mod the rubbers for piece of mind and do the right thing so a heads up on the silicone hose hunt would be good, thangyouverymuch, EP
#2 dapleb
  • 18,394 posts
Posted 06 January 2013 - 04:56 pm
Oi just got a piece off ebay, so long ago now that cannae find it in me archived purrrchases. T'were 60mm diameter oi stink and you need hardly any length. 10cm length should do both soides if ya use same method.
#3 Studley Ramrod
Posted 06 January 2013 - 05:24 pm
Summat to do wi' milking cows iirc. :unsure2:
#4 dapleb
  • 18,394 posts
Posted 06 January 2013 - 05:29 pm
Maybe thats why I can't find it in me ebay archive. :)
Someone repaired theirs with part of a milkin machine at some point oi think.
#5 Crockett
Crockett
  • 24 posts
Posted 06 January 2013 - 06:13 pm
I got some from
http://www.advancedf...-hose-799-p.asp
They do a 75mm straight coupler.
#6 ElvisParsley
ElvisParsley
  • 58 posts
Posted 06 January 2013 - 10:25 pm
Thanks for the input fellas. I've now managed to track down the 60mm hose required from a local company advertising on ebay. If I make a complete arse of it I'll milk the cows for free...
#7 LewisBlackburn
LewisBlackburn
  • 1,748 posts
Posted 06 January 2013 - 10:58 pm
This the stuff that connects the Airbox to the carbs?
Studley told me to get mine done 2 year ago :S oooops :D
#8 ElvisParsley
ElvisParsley
  • 58 posts
Posted 10 January 2013 - 06:17 pm
Job done. The blue stuff is very soft n grippy, works very well. 4 jubilee clips, 1 top and bottom after cutting off the 5mm ish of the airbox rubber skirt. I bought a metre of the stuff from a local company called Hypose here in Southampton. I have a lot left over and am considering passing it on for a small fee in 10cm lengths if anyone is interested...
Edited by ElvisParsley, 10 January 2013 - 06:35 pm.
#9 LewisBlackburn
LewisBlackburn
  • 1,748 posts
Posted 10 January 2013 - 06:25 pm
Job done. The blue stuff is very soft n grippy, works very well. 4 jubilee clips, 1 top and bottem after cutting off the 5mm ish of the airbox rubber skirt. I bought a metre of the stuff from a local company called Hypose here in Southampton. I have a lot left over and am considering passing it on for a small fee in 10cm lengths if anyone is interested...
Sounds Interesting
#10 leehenty
  • 5,325 posts
Posted 10 January 2013 - 06:50 pm
there you go lewis, a way to get yours done now.
#11 stu
stu
  • 2,060 posts
Posted 11 January 2013 - 01:20 pm
Pics, Mr Parsley ?
#12 wideload
wideload
  • 56 posts
Posted 13 January 2013 - 07:47 pm
what does this mod do ?
its this for the mk1 ?
any info/pics about where to fit it.
#13 dapleb
  • 18,394 posts
Posted 13 January 2013 - 07:54 pm
http://www.carpe-tdm...7871&hl=rubbers
#14 ElvisParsley
ElvisParsley
  • 58 posts
Posted 15 January 2013 - 11:11 am
Pics ahoy of the mod and the bike for sale...
http://www.ebay.co.u...9#ht_804wt_1141
#15 dhatfiel
dhatfiel
  • 63 posts
Posted 12 September 2013 - 06:42 pm
I got some from
By the by, I opened this link, as I want to do the Dapleb/Monkey Boy Manuever/Process/Modification myself, and I note that the particular material of the referred to hose is NOT suitable for Oils\Fuels. They recommend Fluoro Lined Silicone Hose. FYI.
#16 dapleb
  • 18,394 posts
Posted 12 September 2013 - 07:58 pm
Thats good to know, will check moine next time in dare.  The way I made mine the silly-cone only clamps to ootside of carb and orig wubber bits butt up against top of carb so non of silly-cone should be exposed but def still worth chicken.
#17 Crockett
Crockett
  • 24 posts
Posted 13 September 2013 - 07:39 am
Your are right about the tube I bought. You shouldnt pass a flow of fuel through it.
However its been fine for over a year, under the air box, no deterioration so no fuel coming back out of the carbs I guess.
