17" Front Wheel
17 Front Wheel
13 replies to this topic
#1 Warren
Warren
  • 2 posts
Posted 09 January 2013 - 09:58 pm
Hi, virgin member here B-)
I need your advice on which 17" front wheel to use for my 2001 Mk2 850?
I have bought a Thundercat wheel (in haste) thats totally wrong (cable speedo on T'cat, electronic speedo on my TDM)
Can you help me and let me know if there is a wheel out there that fits so that the original speedo can still be used?
Thank you in excited expectation.
#2 Studley Ramrod
Posted 10 January 2013 - 09:18 am
I don't see how you can continue using the same speedo with a smaller wheel. Unless you fit a speedhealer or similar.
#3 Warren
Warren
  • 2 posts
Posted 10 January 2013 - 07:38 pm
Thanks for your reply and pointing out the speedo inaccuracies. Would you know the answer on what wheel would suit?
Regards, Warren
#4 Studley Ramrod
Posted 10 January 2013 - 10:46 pm
No idea matey. Godda pic of wan though.
#5 Studley Ramrod
Posted 11 January 2013 - 03:55 pm
Elvis fitted a 17" to his mk1. http://www.carpe-tdm...=26762&hl=wheel
#6 thunderdrum
thunderdrum
  • 27 posts
Posted 21 January 2013 - 09:27 pm
would a trx front wheel fit
#7 dandywarhol
Posted 21 January 2013 - 09:40 pm
It would but still the electronic speedo problem...................
#8 Daveb
Daveb
  • 1,907 posts
Posted 21 January 2013 - 09:50 pm
i could offer a possible solution, a fully programmable speedo with this would over come the speedo inaccuracies when using a different wheel size. The company i work for designs and manufacture gauges.
But it would be an extra expense. not much change from £200 http://www.smithsspeedos.co.uk/
2007 Triumph Tiger 955i
#9 tdm850rider
Posted 22 January 2013 - 04:20 pm
Dave needs a title.... Gauge Guru. :pimp:
#10 Daveb
Daveb
  • 1,907 posts
Posted 22 January 2013 - 09:17 pm
you should see some of the bikes I am working with at the mo, its all hush hush...... but these photos have been published
http://www.facebook....&type=1
http://www.puca.co/i.../pup-detail.jpg
#11 tdm850rider
Posted 22 January 2013 - 09:21 pm
What engine in this?
#12 Daveb
Daveb
  • 1,907 posts
Posted 22 January 2013 - 09:24 pm
Enfield motor,
front forks are modified 125cc and shortened.
Brookes saddle
modified HD tank
and.... SMITHS digital Chronometric speedo :)
more photos here http://www.carpe-tdm...pic=26047&st=20
Edited by Daveb, 22 January 2013 - 09:28 pm.
#13 robelst
robelst
  • 1,844 posts
Posted 27 January 2013 - 04:50 pm
Why not stick a few pointers on the speedo at 30, 50, 60 and 70 mph? Did that on my Buell when I swapped the (very tall) European gearing for the US gearing, nearly 10 years ago. No issue for MOT, all that is needed is a working instrument that measures speed - even one scaled as furlongs per hourglass should pass ;)
That was not a banana, Dougal
#14 ssray
ssray
  • 164 posts
Posted 31 January 2013 - 12:58 pm
Get a cycle speedo, had one on my africa twin when i put a 17 on the front of that
Ray
Also tagged with one or more of these keywords: 17, Front, Wheel
