900 Belly Pan Weekend Project ;-)
Posted 27 August 2013 - 07:19 am
Spent a decent amount of time on the prep and on the last stages now of applying the clear coats, building them up like I did the hard colour, will sand down with 2500 wet & dry then polish and wax.
Not sure what make it is, was looking at a Powerbronze at £80 delivered but fancied a go at this, nice weekend project and all in for less than £40, when fitted will post pictures..
Great use of an old fan, perfect to use in this lovely warm weather as a jig mount ;-)
Posted 27 August 2013 - 07:32 am
Edited by Pict, 27 August 2013 - 07:34 am.
Posted 27 August 2013 - 07:42 am
That looks like Yamaha OEM to me - I have the same. I'd get a Fenda extenda on your front mudguard if I was you, even with one on mine the paint has been worn off at the bottom from the road spray/grit
Posted 27 August 2013 - 07:52 am
Posted 27 August 2013 - 09:11 am
Its a yamaha parts, I put helicopter tape on the fromt bit on mine to protect the paint, as it does take a battering due to where it is.
No more a TDM owner moved on to the Tracer
Posted 27 August 2013 - 01:33 pm
Helicopter Tape?
Posted 27 August 2013 - 02:48 pm
Helicopter Tape?
Here is a little on it;
http://singletrackwo...-tape-on-frames
and here was me thinking it was what they used to stick them back together with after the inevitable.
Posted 27 August 2013 - 07:39 pm
Great idea, have not got a clue what this tape was but found on line and ordered some.... Thanks for the idea Timoc ;-)
Posted 27 August 2013 - 08:43 pm
Called Bike frame tape here, http://www.tape2go.c...e-Frame-Tape/69
Shop around, prices can vary, but its good to put anywhere to protect from scuff's etc. Use it on my mountain bike. Tape2go is one of the cheapest around.
Posted 30 August 2013 - 06:22 pm
Ya can't beat a day of tinkering in the garage with the radio on and a coffee....... Bliss!
Posted 01 October 2015 - 05:18 pm
Helicopter tape has come for the belly pan, going to have a go fitting it on the bike tomorrow with all the gear I've got from DazzerB today. Will post up some pictures of the completed bike when finished.
Any advice on fitting the tape Latestarter? I've now discovered "Helicopter tape" and I think I should cover the £300 custom paint job on my belly pan in it...loads of it!!!
Posted 02 October 2015 - 08:42 am
I think you will find it hard to cover the whole of the pan in tape, its quite ridged and obviously tough stuff ProudViking. Get the area totally degreased, I used some white sprits, cut the tape to the size/shape you want it. Then heat it up with a hair dryer which will made it more malleable to fit to the pan.
Hope this help fella, just take your time and you'll be fine.
Posted 02 October 2015 - 09:06 am
Thanks Latestarter, I shall tinker with it sometime.
