Battery
10 replies to this topic
#1 Yellowasp
Yellowasp
  • 449 posts
Posted 17 January 2007 - 08:09 am
Just a simple question fella's.
Where can I get a cheap battery for a MK11
Yellow Tdm 900 with lots of bits added
#2 Hartside Man
Posted 17 January 2007 - 05:05 pm
QUOTE(Yellowasp @ Wed 17th Jan 2007, 07:54 AM) <{POST_SNAPBACK}>
this place was recommended to me, have a peek http://www.batteryworld.co.uk/
#3 dandywarhol
Posted 17 January 2007 - 07:34 pm
I just bought one on ebay from lenmanchester (Yamaha dealer of repute I seem to remember from the ol' days) £42.50 delivered
#4 GIBBO
GIBBO
  • 463 posts
Posted 22 January 2007 - 08:20 pm
Can anyone tell me how to get to the battery as I need a new one (see post re Spain Trip)?
My body is a temple, that's why my shoes are on the outside.....
#5 tdm850rider
Posted 22 January 2007 - 11:18 pm
QUOTE(GIBBO @ Mon 22nd Jan 2007, 03:05 PM) <{POST_SNAPBACK}>
I'm sure its just like on the Mk1.... quite simple really.
  1. Remove seat and set aside.
  2. Remove left side of fairing and set aside.
  3. Remove right side of fairing and set aside.
  4. Remove center section of fairing and set aside.
  5. Remove bolt and oval washer at rear of tank and set aside.
  6. Remove bolts and fittings from left side of tank and set aside.
  7. Remove bolts and fittings from right side of tank and set aside
  8. Lift tank and turn 90 degrees to right and balance on frame.
  9. Service or remove battery.
Now is a very good time to connect a pigtail to the battery so the next time you want to charge it
you only have to fish the end of the pigtail from under the seat.
#6 dapleb
  • 18,322 posts
Posted 22 January 2007 - 11:53 pm
QUOTE(tdm850rider @ Mon 22nd Jan 2007, 11:03 PM) <{POST_SNAPBACK}>
no.
#7 tdm850rider
Posted 22 January 2007 - 11:58 pm
QUOTE(dapleb @ Mon 22nd Jan 2007, 06:38 PM) <{POST_SNAPBACK}>
no.
I admire the way you avoided attaching any qualifying information whatsoever to that. Can't even tell if it's simpler.
Truely well done, you are the ultimate laconic.
#8 dapleb
  • 18,322 posts
Posted 23 January 2007 - 12:11 am
QUOTE(tdm850rider @ Mon 22nd Jan 2007, 11:43 PM) <{POST_SNAPBACK}>
You can, use the search facility:
http://www.carpe-tdm...o...&hl=battery
http://www.carpe-tdm...o...ic=2249&hl=
#9 Landy
Landy
  • 1,387 posts
Posted 23 January 2007 - 09:50 am
I find these bullet connectors from Rocket Radio very useful and cheap.
They are just right for this job.
OK this is not on my TDM, (cake for the first to name the bike), I have not got around to that little job yet.
It's probablybest if you buy two, you then cut each one off right at the end (double check you leave the gender the way you need it). You can then put some sealant over the wire ends on the reject to make a blanking plug.
Rocket Radio are only offering the 10A connector at present (fine for battery charging) but they usually also do a 30A version for higher current needs.
#10 dapleb
  • 18,322 posts
Posted 23 January 2007 - 11:46 am
QUOTE(Andy K @ Tue 23rd Jan 2007, 09:35 AM) <{POST_SNAPBACK}>
Winston. Woo hoo when do I gets me cake?
#11 Landy
Landy
  • 1,387 posts
Posted 23 January 2007 - 08:59 pm
When you get it right!
