* * * * - 8 votes
5813 replies to this topic
#5361 chrisr
  • 1,748 posts
Posted 26 August 2022 - 10:04 pm
Wish they’d make they’re sodding minds up!
#5362 fixitsan
  • 4,676 posts
Posted 26 August 2022 - 10:28 pm
Yep, well spotted, LED in mine and it's crap at night, completely off, much prefer HID.
""it's crap at night, completely off""
Might have been brighter if you had switched it on...
:hide:
#5363 catsbum
Posted 27 August 2022 - 04:03 pm
My Tester has always passed my hid lights. "It's the cut I'm looking for"
And he always takes her for a run.
Cats
Edited by catsbum, 27 August 2022 - 04:04 pm.
#5364 dablik
  • 10,760 posts
Posted 27 August 2022 - 08:53 pm
:hide:
Smart arse it's on permanently  :P
#5365 catsbum
Posted 28 August 2022 - 05:40 pm
No ridey, no likey
Saturdays little project
Me? I blame Henty
Cats
#5366 Sphere
Sphere
  • 81 posts
Posted 28 August 2022 - 08:46 pm
Very, very nice. But far too clean, you could eat off that!
#5367 catsbum
Posted 29 August 2022 - 06:44 am
Not allowed to ride so things to be done Sphere!
Oil service and crash bars today
#5368 leehenty
  • 5,094 posts
Posted 29 August 2022 - 08:37 am
Stainless or Titanium ? 😍😍
This is the Way.
Edited by leehenty, 29 August 2022 - 08:52 am.
#5369 steve27bha
  • 785 posts
Posted 29 August 2022 - 09:54 pm
No ridey, no likey
Me? I blame Henty
Cats
Aren't the alloy plates between the nut and swingarm meant to be the other way round? i.e. so the chamfered edge is inside and thus avoiding the curve in the corners of the swingarm's U section?
Otherwise the sharp corner edges will take all the pressure of the nut, and tend to bend the plate / make it dig in?
#5370 leehenty
  • 5,094 posts
Posted 05 September 2022 - 01:56 pm
Gave it new oil and filters, done 43k now so it's just about run in. Then gave her a good clean and polish with the good stuff. Brother has his BMW GSA, I have TDM and service it £60 all in. His dealer service quote,they give you a chair to sit on first. Of course, they always say "it's only £££"
#5371 JohnnyW
JohnnyW
  • 313 posts
Posted 07 September 2022 - 02:34 pm
While the front end is still in bits and waiting for the re-chromed forks to come back decided to do a partial service and changed the air filter and spark plugs. I thought the 4tx was bad enough to change the plugs but the Niner is in a different league!🤬 I followed the procedure posted elsewhere on this site which helped enormously.👍
Got the oil and filter in the garage and will get them changed once the bike is back on two wheels.
#5372 Favs
  • 4,396 posts
Posted 07 September 2022 - 08:48 pm
Yep u is correct. Deffo chamfer to SA.
#5373 steve27bha
  • 785 posts
Posted 10 September 2022 - 09:44 pm
I took mine for a long (306 miles) cross-country run down to Whithorn in Dumfries & Galloway, and ate the sarnies at Isle of Whithorn harbour, in glorious sun.
Attached File  DSC02829.JPG   177.9KB   3 downloads
#5374 drewpy
  • 1,759 posts
Posted 11 September 2022 - 04:01 pm
gave mine a wash from last weekend.
much better now
#5375 chrisr
  • 1,748 posts
Posted 11 September 2022 - 08:50 pm
Noticed that it needs a new rear tyre, when I checked found it had done 12,000 miles so can’t complain!
#5376 Favs
  • 4,396 posts
Posted 24 September 2022 - 05:27 pm
Fitted black handlebars - Renthal 755.
#5377 Favs
  • 4,396 posts
Posted 27 September 2022 - 05:01 pm
New handguards fitted today - DRLs to be applied when the rain stops.
#5378 Sphere
Sphere
  • 81 posts
Posted 27 September 2022 - 05:17 pm
Which ones did you fit? I've yet to see any I like that fit with std bars, are yours only compatible with the Renthals?
#5379 Favs
  • 4,396 posts
Posted 27 September 2022 - 07:09 pm
These guards...https://www.ebay.co....tm/255586919478
They are ABS - likely to break easily( :huh: )
Handlebars - I tapped them for std bar weights which have been drilled n tapped to accept M8 fixings.
Quick sketch
Attached File  bar end weight.jpg   8.31KB   0 downloads
Brackets supplied with guards do NOT fit. I made some from 19 x 3mm aluminium strip about 100mm long (each) I had in stock.
DRL strips are these type https://www.ebay.co....tm/155011162690
DRLs are coupled to Fixitsan's excellent controller :good:and they cover the yellow band on the front of the guards
HTH
#5380 Favs
  • 4,396 posts
Posted 28 September 2022 - 12:45 pm
No rain this morning = DRLs fitted and functioning just fine :good:
