Hard To Start - Valve Timing Out A Tooth?
timing starting backfire 850 mk1
5 replies to this topic
#1 mh1848
mh1848
  • 507 posts
Posted 02 May 2015 - 08:34 am
well I did my shims a while ago - and also overhauled the carbs (new tubes and seals) but then had a period of ill health - and also had some other bits and pieces to do (new front disc, tyre and wheel bearings) - so its only been the last couple of weekends i have been trying to get it up and running
it is very reluctant to start (spark fine, plenty fuel getting through) tries to fire up and catches a couple of times but just wnot pick up - got it running eventually last week and after a while did even out and sounded not too bad. -  but this week - pops and bangs and flames up carb inlets - catches bu would not pick up
but i have a nagging suspicion that the timing may be one tooth out - i used to have a XS250 that would not start when warm and it was a valve timing issue - so if one tooth out one way makes it hard to start when warm, ....................
any thoughts before i take cam cover off again?
cheers
#2 Studley Ramrod
Posted 02 May 2015 - 08:48 am
Difficult to say for sure, new toobs could mean you need to adjust the pilots and do a carby balance. Also, being stood for a while doesn't always help. I guess the only way to eliminate the timing slip is to check.
Mine was a poppin an fartin on start up, had a leak in the vacuum pipe which was letting air into the intake and also caused the fuel pump to struggle.
#3 dapleb
  • 18,356 posts
Posted 02 May 2015 - 09:54 am
Heya mh, sorry to hear you have been poorly.
As SR. I would.be chicken.the carbs again.too. though the tooth ooot thing shouldn't be too hard to.check.
#4 mh1848
mh1848
  • 507 posts
Posted 07 May 2015 - 01:25 pm
thanks for advice guys and as you say will try checkin the carbs agin - as i said new emulsion tubes, new seals, new needles and circlip on correct notch, mixture screws 2 1/2 tunrs out, fuel levels set correctly
if it still does not catch then will bite bullet and check valve timing
my ill health was a ruptured appendix - followed up by a secondary infection resulting in a week on drips and loss of about a stone in weight and five weeks off work
#5 Kelpie
Kelpie
  • 944 posts
Posted 08 May 2015 - 06:38 am
Ugh! Been there and done that. Well done for surviving a horrendous time! I hope you're getting over it and feeling much better!
#6 dapleb
  • 18,356 posts
Posted 08 May 2015 - 09:51 am
Ughhh glad you made it through mh!!!!
Lettuce snow how ya get on with the boike.
Also tagged with one or more of these keywords: timing, starting, backfire, 850 mk1
