Tdm Fails On Road - Arghghgh
electrics control unit fail help
30 replies to this topic
#1 Sue
Sue
  • 7 posts
Posted 05 May 2015 - 08:55 am
Hi, my first time on the forums and a newbie to the website but I am hoping that someone out there is able to help as I really want my bike back on the road!!
Last week my 2002 TDM 900 passed her MOT (having been fully checked over following the chain-tensioner sticking so the swing-arm had been taken off, sorted & returned). The next day my son took her out for a ride (as he does very occasionally). Here's his short review of what ended up as the Police blocking an entire lane (and being very chatty and friendly with my son), a £150 recovery & one very pi**ed off son & mum:
 Bike started fine. A minute(ish) after dip beam failed so I presumed blown bulb & switched to main beam. All seemed ok but then bike cut out completely, seemingly all functions on right-had switch failed. Tried to re-start the bike but as if the kill-switch has been hit. After recovery & back in the garage ... it started just fine!
Friend & excellent mechanic has checked all connections & can't find anything wrong & doesn't want to take the control unit (or whatever the technical name is) apart as he's not familiar with this bit of kit - any suggestions?
I can't rider her unless I know it's not going to happen again.
Can someone help please???
Yours hopefully,
Sue :o
Edited by Sue, 05 May 2015 - 08:56 am.
#2 Studley Ramrod
Posted 05 May 2015 - 09:11 am
:welcome:  to the club Sue !  Sorry to read your first post is a cry for help.  Have you/ the mechanic checked the error codes to see if anything untoward is showing ?  Have a look here  http://www.jbx9.16mb...?page=ERR_CODES
Wherabouts are you ?  There might be someone on here close to you who can come and have a look.
#3 muddy
Posted 05 May 2015 - 09:32 am
Firstly, welcome to yer. Secondly, I only groked that the right-side chain adjuster bolt must've seized and the rest is the dark arts of electrickery and way beyond me, but I'm sure someone here knows something and will give some ideas and suggestions.
#4 Matlock
Posted 05 May 2015 - 09:53 am
Hi & welcome. I had similar issues myself some years back, but not so dramatic!. Under the fuel tank and air box, all the cables from the handlebar switches join in with the rest of the wiring loom in a variety of multi-pin plugin connectors. My problem was a poor connection somewhere in there. The solution was simple.
  • Off with the fuel tank & air box.
  • Pull apart each connector one at a time; visually check the connections, looking for dirt.corrision and clean with electrical contact cleaner. Push the two parts of the plug back together and pull apart again a few times and then push them together again one last time (this cleans up the electrical contacts).
  • Repeat for each connector.
  • Reassemble and test.
Go carefully, yours is a yellow one (the best and fastest colour ;) ), so 2002 model year. Those connectors are 13 years old, so they and the wiring will be starting to get brittle. Good luck  :good:
#5 Kelpie
Kelpie
  • 944 posts
Posted 05 May 2015 - 11:11 am
Delighted to welcome a another lady TDMer to the forum and hope you get your bike fixed.
Intermittent electric faults are a real pain! The only time I ever had a problem was with a loose connection on the ignition coil after hitting a pothole.
#6 JBX
Posted 05 May 2015 - 03:52 pm
Intermittent electrical faults are mainly due to bad connections, the engine control unit is not in cause.
About the connectors, Matlock said it all. :good:
I mean that's specific to 2002 yellow models, 2002 silver models connectors are doing well. :)
Edited by JBX, 05 May 2015 - 03:53 pm.
#7 celticbiker
celticbiker
  • 1,726 posts
Posted 05 May 2015 - 06:33 pm
My post here might point you in the right direction of the connectors of which Matlock speaks.
http://www.carpe-tdm...l=&fromsearch=1
Where are you based?
#8 dablik
  • 10,890 posts
Posted 06 May 2015 - 09:01 am
Welcome to the forum Sue, sure you will be sorted in no time, most issues with the TDM are usually resolved pretty easily and you certainly came to the right place,   :good:
#9 RogerD
RogerD
  • 241 posts
Posted 06 May 2015 - 09:11 am
Welcome Sue. As you can see there are plenty of knowledgeable folks to offer help here. Good luck with this one....electrics are a royal P in the A. but TDM is pretty good overall.
Roger
2004 Silver TDM 900, Scorpion cans, MRA screen, Heated Grips, Piramid Fender Extenda. Mitchelin PR3's, Oxford Soft luggage.  Now living with Sidestand
#10 Sue
Sue
  • 7 posts
Posted 06 May 2015 - 09:36 am
Thank you all VERY much.
I love my TDM & want to get her back on the road asap. I am studying for an MSc & have some homework to do which is taking up too much time this week (yes I know, at my great age I should have known better than to start a degree when I left school at 16 :istupid: ).
In answer to 'Studley Ramrod' I live in the Peterborough/Huntingdon area & to 'Matlock' - dun that to no avail :sorry:
I use to be an electrician in my dark & distant days (ex-RAF) but I've forgotten more than I knew ... & bikes just go to prove that men like fiddling - if women designed bikes all the cables & fiddly bits would be easy to access without being a contortionist who has too much time on their hands & likes getting covered in oil & muck!!  :isurrender:
again,  :signthankspin:  to you all ... I look forward to getting to meet you somewhere ... and preferable on a road not in my blinkin' garage!  :)
#11 Studley Ramrod
Posted 06 May 2015 - 10:03 am
Sooooo, did the dipped beam actually fail ?
If not, errrrrm, have you ruled out possible user error ?  I remember riding in the dark when I first got my TDM and accidentally resting my thumb on the kill switch, didn't even feel the switch go. 10 mins of head-scratching and a big 'doh' moment and all was good ! :)  Also fumbling in the dark for the headlight switch produced interesting results.
#12 TinTin
TinTin
  • 1,296 posts
Posted 06 May 2015 - 10:32 am
Could still be a furry kill switch SR. I have had them cause very intermittent probs or what about the side stand switch.
I have also read on the ER6 forum that a dealer changed the complete wiring harness on a bike & it was the clutch switch in the end. :lol:
Try the simples first
#13 Studley Ramrod
Posted 06 May 2015 - 01:32 pm
A furry kill switch or dodgy sidestand switch would cut the engine but wouldn't cause low beam to fail, hence me asking the question. :)  Plus, all electrics have been checked out by the friendly excellent mechanic.
#14 JBX
Posted 06 May 2015 - 02:27 pm
It looks like a main switch intermitent failure.
A common issue if your keyholder is full of keys.
#15 Sue
Sue
  • 7 posts
Posted 06 May 2015 - 03:01 pm
Wow this is an active forum  :)
Defo not rider error, nor too many keys - just the bike key, one lock & my house key + a very light keyring. He was trying out his new gopro so had it all on film, so he could prove it wasn't just him having a 'mum' moment - yes, I did once hit the kill-switch in error when I was chief marshal of 500 bikes ... oh how they did laugh ... :huh:  :lol:
Hope to have a go at it this weekend but I'm at the National Arboretum this Saturday & HAVE to try to get my last 2 assignments done so I can concentrate on my dissertation.
ps - love the emoticons but why no smileys on bikes in there?
Edited by Sue, 06 May 2015 - 03:03 pm.
#16 leehenty
  • 5,314 posts
Posted 06 May 2015 - 04:18 pm
Go over all the joints cleaning and applying ACF50 to the connectors before you put them back together.
You will have to get the tank up and airbox off which will entail removing side panels. It's easier with a tank prop.
I'm not too far from you so if you have somewhere to work under cover, I could take a trundle over there with a few tools and meters and have a look at what the problem might be.
Bikes are designed to work, men don't 'fiddle' we carry out  repairs using sound engineering principles... or we ought to.
The only few known niggles on the niner are easily sorted.
Edited by leehenty, 06 May 2015 - 04:21 pm.
#17 Phil McLaughlin
Phil McLaughlin
  • 164 posts
Posted 06 May 2015 - 04:36 pm
Id go for the switches again.  Take them off the bars & have a look, prod, squirt ACF50 in them
has the bike been laid up for any length of time (allowing corrosion to build on contacts ?)
how are the earth points ?
Good luck !
#18 divvxj
divvxj
  • 1,296 posts
Posted 06 May 2015 - 05:29 pm
.hi and welcome , do you like :cake eating: ,any hoo , when my niner was in getting valves checked , the tank was up so the mechanic could see that some of the connecters were badly corroded but then I do ride the bike in all weather and it doesn't matter how much you wash the bike , that salty crap on the road will get into all the wrong places :good:  :good:
#19 RogerD
RogerD
  • 241 posts
Posted 06 May 2015 - 09:33 pm
Sue....you have an offer from LeeHenty to help...thats the best route to salvation....just provide hot drinks and a flour based food product (cake) and you are sorted!
Roger
#20 Kelpie
Kelpie
  • 944 posts
Posted 07 May 2015 - 09:51 am
+1
The man is a genius!
Also tagged with one or more of these keywords: electrics, control unit, fail, help
