Clutch Work
service clutch repair
3 replies to this topic
#1 Galilee
Galilee
  • 892 posts
Posted 28 June 2015 - 07:04 pm
I'm suspecting my clutch need replacing so i'm wondering:
- do i order just the friction plates, or should i also get the steel ones?
- the parts list i have (for the 4TX) has two different partnumbers for the friction plate (2 of one type and 7 of the other), and then 8 clutch plates. is it correct that i need all of these?
- anything else i should replace wihle i'm at it? Release bearing?
I seem to remember hearing that the clutch squeal can be avoided by modification to the clutch basket. Does anyone have info on this?
#2 Dougie69
Dougie69
  • 95 posts
Posted 28 June 2015 - 10:24 pm
Can not advise you as to weather you need to replace everything but I would recommend putting the new plates in oil for a min of 48hrs a fiend of mine forgot to do this and ended up having to re do everything again within a few months good look
#3 Sidarta
Sidarta
  • 845 posts
Posted 29 June 2015 - 02:37 am
Hi Galilee!
Ideally disassemble, to assess the whole. Check if the thickness of the disks (fiber) and length of the compression springs 6 are within tolerance.  The metal discs (on a glass plate) to give slack or buckling.
Looking at the parts catalog I also was in doubt:
item 8   = 7 disks fiber   = ok
item 12 = 8 metal discs = ok
item 7   = 2 disks (also in fiber?) are thicker than those of item 8 ??
I never needed to disassemble the clutch of my 850.
Cheers!
Att
Sidarta
TDM850 ano 2001
 Honda XLX 250 1988
Honda CB350 1972 e 1973
#4 AlanG
AlanG
  • 109 posts
Posted 12 July 2015 - 02:37 pm
Just picked up on this. I've just replaced all the plates ( friction & steel) plus springs & bearing. Paid Yamaha prices but hopefully should last a while. Pressure plate only requires 8 Nm torque so go carefully
Also tagged with one or more of these keywords: service, clutch, repair
