Coolant Coming Out Of Overflow Pipe When Hot
Posted 17 September 2015 - 10:31 am
Posted 17 September 2015 - 11:03 am
I had a similar problem with the Tiger, mine turned out to be rad cap, I some guys fitted aftermarket ones but had a different pressure reading from OEM.
have you checked the thermostat?
temp sender? have you got a temp gauge fitted, what does it read when fan cut in.
sensor for fan - dodgy?
2007 Triumph Tiger 955i
Posted 17 September 2015 - 11:05 am
it may be a number of things Pantboy, May be an airlock , temp sender not coming on on time , a leak somewhere letting air in or at worst the head gasket going or the water pump failed . I would wait for a few more learned members for their input as I have only had mine a short while and there may be other faults that bring this thing on.
Good luck anyway bud
Posted 17 September 2015 - 11:39 am
Posted 17 September 2015 - 01:05 pm
Some time ago i had the radiator off and mixed up the two pipes just below the rad cap and just before the fan came on it ejected the coolant
onto the floor as if wasn't going back into the expansion bottle
Have you had the radiator of recently?
gilly
A shin is a device for finding furniture in a dark room
A sure cure for seasickness is to sit under a tree
Posted 17 September 2015 - 02:16 pm
mine went very high while out today mate and If I remember the fan cuts in just before redline , dont quote me on that but 2 minutes later it was down to half way so I think that the TDM fan should cut in a bit earlier for me as it used to on my Fazer.
Posted 17 September 2015 - 02:30 pm
gilly
I haven't, but that's not saying someone else hasn't, the bike has been in for a service at a local garage, how do I check if the pipes are connected correctly?
Posted 17 September 2015 - 05:08 pm
Hi Pantboy
There connected the wrong way round just swap them round and check your coolant level in radiator and expansion bottle
The thin pipe needs to be at the top next to rad cap
gilly
Edited by gilly, 17 September 2015 - 05:51 pm.
Posted 17 September 2015 - 06:11 pm
Hi Pantboy
gilly
i'll swap them over in the morning, fingers crossed that is the problem.
As far as I know the pipes have always been like that, the rad has never been off during my ownership, coolant has been changed, but I presume there would be no reason to touch them pipes to drain/refill the system.
Posted 17 September 2015 - 06:41 pm
You might need to take them off, for a 24,000 service when you check the shims or to change the spark plugs if you want plenty of room.
Posted 17 September 2015 - 09:10 pm
Exactly. When Lee did my valve check, I almost put them back the wrong way. Lee pointed out that I was putting them the wrong way round and said the result would be exactly as you describe.You might need to take them off, for a 24,000 service when you check the shims or to change the spark plugs if you want plenty of room.
Ali
Posted 18 September 2015 - 08:09 am
Thanks all, with a special mention for gilly for being daft enough to connect them the wrong way round in the first place but big enough to admit the mistake to help a fellow idiot, next round is on me if we ever meet
Posted 24 September 2015 - 06:43 pm
Just glad it helped
Gilly
