3Vd Starter Issues
13 replies to this topic
#1 Godzillamonster
Godzillamonster
  • 109 posts
Posted 02 October 2016 - 03:33 am
Hi all,
My trusty old 3VD has been a bit problematic starting lately.... I'd press the starter button 3 or 4 times and only hear click from starter solenoid relay then finally starter motor would crank & start the bike.
Time for a new starter solenoid relay I thought.
I have a few spares from another 3VD so proceeded to swap starter solenoid relays - no joy.
While swapping solenoids back my socket dropped off the driver and shorted across the solenoid terminals. Bugger, that's fried it.
Now instead of click, click, click start nothing happens when I press the starter... really time for a NEW starter solenoid relay I thought. Yes, have also replaced blown fuse.
Ordered one from ebay for $12US & have been shorting across the terminals to start the bike in the interim.
New solenoid arrived & installed - still no action when I press the starter button.  :sorry:
Have lost my wiring diagram.. anyone got an idea where the problem still likely to be? (beside seat and keyboard?)
Normally such a reliable old beast - will crack 400,000 kms next oil change.
20 months on the road riding overland from England to New Zealand on a '91 TDM850.
http://www.horizonsu...richardandlisa/
TDM round the world - YouTube
290 000 kms before gearbox blew, 190,000 on 2nd motor and still my daily wheelie commuter sports hack
#2 fixitsan
  • 4,827 posts
Posted 02 October 2016 - 07:54 am
Start with checking that one of the two solenoid wires switches to 12v when you press the button, and that the other is a solid return to ground.
If the sol is new it must be a fault on one of those wides
#3 Sidarta
Sidarta
  • 845 posts
Posted 02 October 2016 - 04:31 pm
Hi Godzillamonster!
The Start button may have poor contact due to oxidation.
Or collector armature starter / brushes are dirty or worn.
With a cable thicker wire, try to make a direct connection test the battery to the starter.
Cheers!
Att
Sidarta
TDM850 ano 2001
 Honda XLX 250 1988
Honda CB350 1972 e 1973
#4 rustyscrew
rustyscrew
  • 126 posts
Posted 02 October 2016 - 09:29 pm
is ur battery knackered, check all the electric connectors on the bike, especially the flag terminal connectors into the ignition coil. ( i learnt the hard way) i m sure if u have 400k km on the beast the connectors wouldnt say no to a good clean anyway.
#5 Godzillamonster
Godzillamonster
  • 109 posts
Posted 08 October 2016 - 01:01 am
Hi all.
Still haven't identified where the issue is....
I need a wiring diagram to trace the starting circuit. Is there somewhere I can download one - have lost that page from my Haynes manual...
The starter relay is working & starting the bike when I get apply power to the blue-white wire to it.
Starter circuit broken somewhere upstream of the starter button - no voltage either side of the switch but am scratching my head following the circuit without a wiring diagram
Help please
#6 Rallyist
  • 3,266 posts
Posted 08 October 2016 - 07:35 am
download from here http://www.jbx9.16mb...ex.php?page=DOC
#7 Catteeclan
  • 2,527 posts
Posted 08 October 2016 - 07:48 am
From the Haynes manual so it's prob wrong anyway. :lol:
Edited by Catteeclan, 08 October 2016 - 07:49 am.
#8 Godzillamonster
Godzillamonster
  • 109 posts
Posted 09 October 2016 - 10:56 am
Awesome, thanks :badgerrock:
#9 wicklamulla
Posted 24 May 2019 - 03:49 pm
Richard,  how's it goin 'down there',  TDM stihl goin strong i hope?  Is it on the original enjun and has it had a rebuild yet?  W
#10 Godzillamonster
Godzillamonster
  • 109 posts
Posted 25 May 2019 - 06:20 am
Sadly, the old girl has been retired just shy of 500,000 kms - at least for now.
Got too complacent with the reliability and ran it low on oil.
A month or 2 after the next oil change my big end bearings (I suspect) gave up on my way home from work - horrific rumble from the motor and power dropping off by the kilometer. Still got me home though.
That was a couple of weeks before we left NZ and moved to Bali.
Been here 2.5 years now and am getting around on a KLX250 which works well here. Lots of wheelies and general anarchic riding.
TDM is sitting in a farm shed in NZ awaiting our eventual return.
If I can find a replacement motor I'll bring it back to life. TDMs rare as hens teeth in NZ so will have trouble sourcing a replacement...
#11 Studley Ramrod
  • 19,345 posts
Posted 25 May 2019 - 08:56 am
Good to hear you're alive and well. :)  You might find the engine to be repairable ?  Maybe new shells and a crankshaft regrind and bingobangobongo !
#12 wicklamulla
Posted 25 May 2019 - 10:09 am
enjoy yer new home.  Man thas some serious mileage for any motor let alone a TDM.
#13 dapleb
  • 18,301 posts
Posted 25 May 2019 - 10:45 am
Boop
#14 poppykle
poppykle
  • 85 posts
Posted 27 May 2019 - 02:53 am
500,000km !  That is a brilliant result, not too many bikes get that far.
