"l" Bracket For Drl's - Engine Mounts
5 replies to this topic
#1 dmmsta
dmmsta
  • 3,627 posts
Posted 15 October 2016 - 11:02 am
Mr Henty kindly made me some longer mount bolts to account for the brackets I'm going to make for DRL fitting.
I'm yet to make the brackets, but the new bolts have dimensions to allow for 3mm material.
The question I have is how wide should I make the brackets?
Do they need to be same/wider than the mount bolt head/washer?
Just for reference this is the bolt in question:
Attached File  TDM 900 Engine Mount.png   990.34KB   0 downloads
#2 Latestarter
Latestarter
  • 676 posts
Posted 15 October 2016 - 12:00 pm
I bought these from Rafal @ RM-G in Poland for £20 inc the mount bolt. Goes well with the crash bars I bought rom him too.
Hopefully it should give you an idea dmmsta.
Chris
#3 dmmsta
dmmsta
  • 3,627 posts
Posted 15 October 2016 - 10:11 pm
Thanks for the photo's Chris.
I'd seen those mounts of yours before.  However I'm on a different track.
The "L" bracket will go between frame and engine mount bolt.  What I'd like to know is should I be making the bracket the same width as the bolt head, or a bit bigger...I assume not smaller!!
#4 dablik
Posted 15 October 2016 - 10:34 pm
You need to make the hole for your bracket the same size as the bolt shaft, if i recall it's 12mm, measure your new ones, if you make it the same size as the bolt head you wont be able to secure it.
#5 Hombre
Hombre
  • 449 posts
Posted 15 October 2016 - 10:41 pm
The same width as the diameter of the spacer that the bolt passes through.
#6 dmmsta
dmmsta
  • 3,627 posts
Posted 16 October 2016 - 06:01 am
I'm not that silly... :P
