Tdm 900 - Wheel Bearing & Seal - Shopping List
bearings wheels shopping list Koyo Simply Bearings KB
8 replies to this topic
#1 dmmsta
dmmsta
  • 3,627 posts
Posted 28 May 2017 - 01:18 pm
Every time I need new bearings I have to hunt for the post from Mr Henty, which lists the bearings & seals needed to do front & rear wheels (inc sprocket carrier).
So I thought I would put the basket contents in one post and ask if it can be added to the KB for an easier time for all.
All bearings are Koyo, as I've never had trouble with these and are consider "high quality", all items (bearings & seals) are sourced from Simply Bearings, based on previous experience and great customer service.  You will find the same parts cheaper elsewhere, but I'm happy to pay that bit extra for the seller quality as well as the part quality.
The below came to just under £80 delivered (at time of writing post).
Front Wheel
Bearings
2x KOYO 60/22DDU Rubber Sealed Deep Groove Ball Bearing 22x44x12mm
Seals
2x 28x44x7mm Nitrile Rubber Rotary Shaft Oil Seal with Garter Spring R23/TC
Rear Wheel
Bearings - Wheel
2x KOYO 60/28DDU Rubber Sealed Deep Groove Ball Bearing 28x52x12mm
Bearing - Sprocket Carrier
1x KOYO 62062RS Rubber Sealed Deep Groove Ball Bearing 30x62x16mm
Seal - Sprocket Carrier
1x 40x62x8mm Nitrile Rubber Rotary Shaft Oil Seal with Garter Spring R23 / TC
Seal - Wheel (Disc side only)
1x 35x52x8mm Nitrile Rubber Rotary Shaft Oil Seal with Garter Spring R23 / TC
Obviously there is no need for a 2nd wheel seal, as the sprocket carrier covers one side of the wheel.
#2 Studley Ramrod
Posted 28 May 2017 - 04:46 pm
:good:
#3 ramo
ramo
  • 1,190 posts
Posted 28 May 2017 - 09:21 pm
I bought the same bearings and seals from here 2 weeks ago, £39.95 delivered
Edited by ramo, 28 May 2017 - 09:22 pm.
#4 dmmsta
dmmsta
  • 3,627 posts
Posted 29 May 2017 - 06:24 am
Blimey
Thats a significant saving!
Worth saving that seller!
Thankfully I haven't click "buy" yet...
#5 TDM4ever
TDM4ever
  • 302 posts
Posted 29 May 2017 - 08:59 am
Good work  :good:
#6 tomekc
tomekc
  • 87 posts
Posted 22 June 2017 - 05:09 pm
Well done, just last thing to close the subject. Does both versions of 9er (Non ABS and ABS) used the same bearings?
#7 hallrob1
hallrob1
  • 1,112 posts
Posted 23 June 2017 - 10:25 am
Blimey
I used the same place last time, and they didn't list a kit for the Tiger but the price was about the same when I gave them the sizes
#8 dmmsta
dmmsta
  • 3,627 posts
Posted 23 June 2017 - 10:50 am
Yes - bearings are no specific to ABS/Non-ABS.
#9 dmmsta
dmmsta
  • 3,627 posts
Posted 27 June 2017 - 07:22 pm
Ordered from the ebay seller linked about yesterday - arrived today.
Fantastic service - WELL RECOMMENDED.
Also tagged with one or more of these keywords: bearings, wheels, shopping list, Koyo, Simply Bearings, KB
