Stability issues when changing tyre sizes
Posted 09 March 2007 - 10:11 am
In the quest for a sticky front tyre and quicker steering I have an exup front wheel, which will be going on once it is painted, which is significantly wider than stock.
Does anyone know how stability will be affected when fitting a wide front tyre. Drag bikes use a skinny front so will a wide one upset or improve straight line stability? Will it notice? Is there any mileage in fitting a wider rear to compensate?
BTW I have started a new thread about choice of rear wheel here
Guest_GuyGraham_*
Posted 09 March 2007 - 12:49 pm
wider tyres are inherently more unstable than narrow ones.
the best to unfderstand it it is like this
Imagine rolling a bicycle wheel and a roll of carpet down a hill. The Bicycle wheel will be more stable than the carpet roll, which will get kocked from side to side.
Going from 110 to a 120 on the front ain't gonna might a huge difference to stability
Posted 09 March 2007 - 01:39 pm
A bigger footprint means more grip so higher cornering speeds but also more convincing is needed to get it into that corner, and usually lines on roads are more noticeable while braking in corners can set the bike more upright.
I would have thought though that on good quality tarmac stability will be better rather than less?
A friend of mine has got an old BMW R90S, running very slim BT45 tyres (I think the rear is only 120
Edited by robelst, 09 March 2007 - 01:42 pm.
Posted 09 March 2007 - 03:07 pm
The guy made a mistake - he mistook the 900 for a 850, that's sooooo stupid - and fitted a 110 in place of a regular 120.
I didn't notice it at once, shame on me !
The bike handled ok in straight lines but was very unstable in curves.
I then noticed the problem & went back to the shop quickly...
Another story : I saw once in Corsica a TDM900 with a 180 at the rear and asked the owner about handling.
He said it was ok and had more grip (roads there are very curvy), he also showed me the footpegs as an evidence.
Posted 09 March 2007 - 06:55 pm
If that 180 was fitted on a standard rim (5" wide or maybe even less?) then the tyre would have bulged out, most likely leading to less rather than more grip
Edited by robelst, 09 March 2007 - 06:56 pm.
Posted 09 March 2007 - 09:08 pm
17" on the front ( I used a Tcat wheel running 120/70-17 ) improved things no end in my opinion quickened up the steering didn't seem to have any probs with stability - drag bikes aren't really made for cornering. I could have and was going to try a 110 section on it but then I wrote the bike off & there didn't really seem any point
CB125 SUPERDREAM, DR125, MZ125ETZ, CD200BENLY, CB250SUPERDREAM x 2, VT250F, XT350,SRX400,CX500EC,XT600,GPX600C1,TDM850MK2,GS850,TDM850MK1,XJ900F,SV1000S, SV1000N, TDM850MK1 (nr2), TDM850 MK1 (nr3),TDM850 MK1 (quatre)
Posted 10 March 2007 - 04:07 pm
If you are trying to make us jealous you have succeeded with me
That is exactly my point about cornering. They have skinny fronts and fat backs for stability (among other reasons). Thanks for this info, nhs, it is exactly what I was hoping to hear
