Michelin Sirac Tyre
MIchelin sirac tire tyre
9 replies to this topic
#1 MikeyMex
MikeyMex
  • 27 posts
  • Location:Jalisco the birthplace of Tequila and Mariachi
Posted 31 October 2017 - 03:14 am
Hi guys,
Just a quickie, Michelin Sirac 110/80-18 TT58R tyre, Michelin market it as a REAR tyre.  Can I use it on the front of my 92 TDM 850? I know it fits the rim but will it perform very well?
DT50M '78, KH100EX '86, RD350LC (many), RD250LC '83, VF400F '83,  Z200 '77, RD400 '76, LTD450 '88, R45 '80, R100RS '82, GSX750SE KATANA '84, FJ1200 '92, GPZ750A1 '84, R100CS '78, (then came 17 years in Mexico and hundreds of Chinese scooters later.... I finally get another real bike) TDM850 MK1 '91 and a KLR 650 '88 for the rough stuff.
#2 g650xtdm
g650xtdm
  • 295 posts
Posted 31 October 2017 - 05:16 am
I can't tell you if it will perform well, but most people reverse the tread when mounting a rear tire on the front.  It is done fairly often, so I doubt there is any danger in it.  Not ideal, but probably not an issue either.
#3 MikeyMex
MikeyMex
  • 27 posts
Posted 31 October 2017 - 08:21 am
Thanks for the opinion, I am of the same mind, reverse the tread.  You're right it's not ideal but where I am (pacific coast Mexico) my selection is very limited, don't wanna go full dirt knobbly tyres, but need something to cover fairly rugged terrain sometimes.
#4 g650xtdm
g650xtdm
  • 295 posts
Posted 31 October 2017 - 11:27 pm
It looks like they make a Pirelli MT60 in a 110/80-18.  The Michelin T63 looks like a knobby, but it isn't very aggressive.  They make it in a rear, but I don't think it is directional.  Good luck and enjoy your trip!
#5 Studley Ramrod
Posted 01 November 2017 - 10:59 am
Hi, there are a few on here who have reversed a Sirac.  Try searching the All about TDM section for sirac. ;)
#6 chrisr
Posted 01 November 2017 - 08:28 pm
What’s the reason you reverse them?
#7 Bjørge
Posted 02 November 2017 - 06:25 am
Methinks it is about longevity :disbig:
#8 fixitsan
  • 4,855 posts
Posted 02 November 2017 - 08:40 am
I heard it's because when fitted as a rear tyre the tread pattern is designed to give best traction under drive. When fitted at the front the tread pattern is reversed to give best traction under braking.
Or blind summit like that
#9 Swarf
Swarf
  • 314 posts
Posted 03 November 2017 - 03:20 pm
Carcass construction, apparently the layers overlap one way to cope with acceleration forces on a rear tyre and the other way to cope with braking forces on the front.
#10 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 03 November 2017 - 08:37 pm
Concur. If you don't reverse a rear on the front the braking forces are opposite and pull the lamination joins apart.
Also tagged with one or more of these keywords: MIchelin, sirac, tire, tyre
