Rubber Fairing Mounts On Tank (9'er)
rubber bodywork plastics fairing screws tank
7 replies to this topic
#1 Gowza
Gowza
  • 88 posts
Posted 14 June 2018 - 08:47 pm
Looked through previous posts and maybe this is a problem only I'm having...
The top rear fairing screws (under the 'twin 900' badge) screw into a small rubber grommet with a threaded brass insert which sits in a loop mount on the tank; as I've discovered they split easily.
An old spare one knocking around took me for firkin' ever to get in as they have to go in from the tank side, but that's now split. I've packed it from behind but getting the screw in is still a hit and miss affair.
Anyone got an easy solution?
"To do is to be." - Socrates.
"To be is to do" - Immanuel Kant.
"Do be do be do" – Frank Sinatra
#2 Muppdog
Muppdog
  • 305 posts
Posted 14 June 2018 - 09:17 pm
Get a new one. They then slide easily into the holes and expand on tightening. Most dealers will stock them. Just don't get original Yam ones. Pricey!
#3 Favs
Posted 14 June 2018 - 09:26 pm
Here you go
https://www.ebay.co....353.m1438.l2649
#4 Gowza
Gowza
  • 88 posts
Posted 14 June 2018 - 09:56 pm
Brill, I knew summat was out there but all my search terms came up with nowt.
Order placed as per Fav's link. Cheers both.
#5 dandywarhol
Posted 15 June 2018 - 09:46 am
Well nuts
#6 Gowza
Gowza
  • 88 posts
Posted 15 June 2018 - 09:52 am
Thanks Dandy, two words I won't forget that'll save me a couple of hours in the future.
#7 dandywarhol
Posted 19 June 2018 - 11:40 pm
You're welcome. As long as you check them regularly in the bath you'll always have well nuts
#8 Catteeclan
  • 2,570 posts
Posted 20 June 2018 - 06:08 am
:unsure2:
Also tagged with one or more of these keywords: rubber, bodywork, plastics, fairing, screws, tank
