4Tx Luggage Frames
12 replies to this topic
#1 Apache
Apache
  • 561 posts
Posted 25 October 2018 - 05:48 pm
SW Motech quick release pannier frames
These should also fit 3VD years too.
Kit contents
Attached File  20181025_155003.jpg   72.11KB   2 downloadsAttached File  20181025_155013.jpg   63.88KB   1 downloadsAttached File  20181025_155203.jpg   58.46KB   1 downloadsAttached File  20181025_155230.jpg   165.07KB   1 downloadsAttached File  20181025_155255.jpg   178.63KB   1 downloadsAttached File  20181025_155417.jpg   66.71KB   1 downloads
Frame installed
Attached File  20181025_170336.jpg   118.47KB   0 downloads
Anti theft
Attached File  20181025_170419.jpg   92.45KB   0 downloads
Indicator resited
Attached File  20181025_170405.jpg   120.31KB   0 downloads
Frames detached - 2 minute job
Attached File  20181025_170506.jpg   111.25KB   0 downloads
Tidy up caps in place - very neat
Attached File  20181025_170708.jpg   114.57KB   0 downloads
E21 on
Attached File  20181025_172122.jpg   131.51KB   0 downloads
Overall impression without long term use..very well made..very sturdy despite quick release mechanism...very neat looking bike when not touring...doddle to install - about 3 hours including initial weighing up the job. Bike at handlebars just under 800mm, with E21's on 870mm....
Bad points, the adapter top case mount i.e. the main lock is mounted to the frame via 2 x Allen bolts. Anybody with a 6mm key could remove the luggage. I may install some anti tamper or shear bolts.
The E21's are a bit pliable which means they flex on the back wall stopping me from push clicking them on and then once on they don't release from the push button for the same reason. No big deal,just open the case and operate the lock by thumb. Sturdier cases should be fine..maximum weight label for the frames including pannier 12.5kg..
Hope that luggage option is useful to someone...
Cost and part numbersAttached File  20181025_185027.jpg   77.4KB   0 downloads
Edited by Apache, 25 October 2018 - 05:51 pm.
#2 Studley Ramrod
Posted 25 October 2018 - 06:02 pm
Thanks for sharing, look good and I didn't realise they fit mk1's. :good:
#3 dablik
Posted 25 October 2018 - 08:10 pm
Nice thing about this system is the ability to detach the frames :good:
#4 JMC
JMC
  • 265 posts
Posted 26 October 2018 - 06:22 pm
Very nice but very expensive, or am I just getting old  :unsure2:
Hunter S. Thompson.
#5 Apache
Apache
  • 561 posts
Posted 26 October 2018 - 07:04 pm
Yeah, expensive I guess. I'm just doing a bit of SKIing ;)
#6 MarshallStone
MarshallStone
  • 38 posts
Posted 24 September 2020 - 12:23 pm
Does this allows you to not drill holes for installment in the bag? I'm looking for a rack that can be strapped up the frame without drilling in the bag. I go these hard saddlebags from viking bags and I'm struggling to install one of these.
#7 steve27bha
  • 797 posts
Posted 24 September 2020 - 08:48 pm
The E21's are a bit pliable which means they flex on the back wall stopping me from push clicking them on and then once on they don't release from the push button for the same reason....
I've used my E21s on three differrent bikes now, and never had this problem. All have, however, been on Givi frames.
I suggest you fiddle with the position of the lock plate and the two buttons and check the latter enter the slots fully. Maybe a wee bit of lube in the lock?
PS If you are new to the E21s take a tip. ALWAYS pull on the handle after locking the lid, since the case can appear shut when it ain't. I lost a camera before I adopted this routine.
Edited by steve27bha, 24 September 2020 - 08:51 pm.
#8 steve27bha
  • 797 posts
Posted 24 September 2020 - 08:57 pm
The cases he has used are Givi E21s which are designed to clip-on / clip off the rack. The fittings - a lock post and two buttons - that hold the case to the rack are not shown in these pix except for in the very first pic.. Go see a Givi site for details of their racks and cases. These are equivalent to the Givi Monokey system.
Here's a pic of a Givi frame showing the lock post and two buttons on the pannier frame and also on the top rack.
http://www.carpe-tdm...=35274&p=357817
ADD: Those you link to are both expensive and small. The stated capacity of the pair converts to 26 litres. Each of the E21s holds 21 litres. You could buy two E21s and the Givi rack for about the same as the price quoted in the advert - in the UK anyway!
Edited by steve27bha, 24 September 2020 - 09:26 pm.
#9 MarshallStone
MarshallStone
  • 38 posts
Posted 28 September 2020 - 01:35 pm
That sounds reasonable. I will definately check it out.
#10 Apache
Apache
  • 561 posts
Posted 30 September 2020 - 11:06 am
[quote name="steve27bha" post="383325" timestamp="1600980529"]I've used my E21s on three differrent bikes now, and never had this problem. All have, however, been on Givi frames.
Hi Steve,
I tried all options to solve this without success. The detachable frames are SW Motech. I just lift the lid . Thumb press the panniers on to the latch and then lock it as normal. Other than that the set up is excellent.
Marshall,
There is no drilling to be done.....
#11 MarshallStone
MarshallStone
  • 38 posts
Posted 01 October 2020 - 01:37 pm
Hi Steve,
Marshall,
@Northcheshire Depends on the rack and distance of the bolts. I wish I could've made a demo video over it to make you understand when I was struggling through it.
#12 MarshallStone
MarshallStone
  • 38 posts
Posted 20 October 2020 - 12:57 pm
Is there any cado system that you guys are using for the head phones in healmet
#13 chrisbee
chrisbee
  • 413 posts
Posted 08 November 2025 - 09:56 am
These panniers, are now fitted to my bike
