Co Setting
5 replies to this topic
#1 MikeD
MikeD
  • 12 posts
Posted 10 February 2019 - 03:57 pm
I'm sure this has been talked about plenty of times! I have not had my TDM900 very long, and love it!
I noticed it can smell a bit rich from time to time, so I thought I would have a bash at adjusting the CO levels. I was intrigued to find both Cylinders were set to +21. With the bike warm and a little bit of throttle both exhausts were chucking out so some smoke. Adjusted them both gradually and ended up on C1 @ +8 and C2 @ +5.
Given the range is -/+ 128, the figures I have don't seem to be  very much. I know every bike is different when it comes to this setting but is what I have typical?
BTW its a 2002 with 32k on the clock, K & N filter and a standard exhaust.
Cheers, Mike
#2 Hombre
Hombre
  • 449 posts
Posted 10 February 2019 - 05:43 pm
Peeps generally change the Co to richen the mixture at low rpm and sort the low speed snatchiness.
Perhaps a previous owner has made adjustments?  How is the slow speed running?
#3 fixitsan
  • 4,852 posts
Posted 10 February 2019 - 06:42 pm
It's good to see you have them at different values. There are differences between throttle bodies, and also one has a long snorkel and the other has a short one (can't remember whether left is long or short), so you can expect different values for that reason
#4 MikeD
MikeD
  • 12 posts
Posted 10 February 2019 - 07:54 pm
Thanks for the replies. When I got the bike I found it a little snatchy but that could of been me getting used to it, I had a Mk1 bandit before. However that seems better now that I have done the airbox mod. Since making the adjustment I haven't been out, but ticks over very smooth
I thought it was odd for both cylinders to be set the same (21), I simply kept adjusting them until the smell and light smoke went. Not very scientific! we will see when I ride to work in the morning if its any better.
I wasn't adjusting for any particular reason, part from interest, I have been working my way around the bike cleaning the filter (KN), oil change, rear brakes and today some fresh antifreeze. So far really very pleased with the bike!
#5 fixitsan
  • 4,852 posts
Posted 10 February 2019 - 08:33 pm
The CO setting is similar to the idle mixture adjustment on carbs, so is really on effective at light loads and low speeds
#6 TKH
  • 2,201 posts
Posted 10 February 2019 - 09:10 pm
Welcome Mick, glad you like the bike.
