Led Indicators Hyper Blinking With Lf1-S-Pin Relay(Flasher)
LF1-S-PIN relay flasher indicator TDM 850 4TX TDM850 4TX blink bulbs LED
2 replies to this topic
#1 zet
zet
  • 1 posts
Posted 21 May 2019 - 08:21 pm
Since I've droped my bike and broken my original indicators I've decided to replace them with LED indicators.
Initially I hoped that LED in front with normal bulbs on the rear will do for the orig.relay, which I was not too informed about how it works exactly initially, I'm no electrician. Then I've found out after, that I need to replace the original flasher with one designed for LEDs, which I did, and bought a LF1-S-PIN relay from China, (actually 5 of them since they were so cheap).
Attached File  IMG_20190520_144802.jpg   81.35KB   1 downloads
Attached File  IMG_20190520_144812.jpg   59.69KB   0 downloads
This kind off sort out the problem, BUT ONLY WITH the ENGINE OFF.
As soon as I start the engine, the flasher starts blinking faster, maybe even a slightly bit faster than the original. But the  only main difference between the original and LF1-S-PIN relay is when indicating with the engine stopped; original is hyperblinking regardless of engine being on/off,  LF1-S-PIN blinks fine just when the engine is off.
I've also tested the  LF1-S-PIN relay with 4 LED indicators (front +rear ) with the same result.
Checked battery with multi-meter, which is in normal parameters.
-cold around 12.6 V,
-idle around 14.x Volts ,
- and about the same on revving over 4K.
I assume these are within range
Any advice ?
Edited by zet, 21 May 2019 - 08:23 pm.
#2 TKH
  • 2,201 posts
Posted 21 May 2019 - 10:31 pm
Is this with ignition turned on or off? I ask as the indicators shouldn't work with ignition off.
You say "I've also tested the  LF1-S-PIN relay with 4 LED indicators (front +rear )" Assume you mean you've tested it with all 4 indicators connected at the same time?
Battery looks ok to me.
#3 Favs
Posted 22 May 2019 - 06:21 am
Greetings.
10w Resistors fitted?
EDIT sorry I assumed original flasher unit.
Edited by Favs, 22 May 2019 - 07:06 am.
Also tagged with one or more of these keywords: LF1-S-PIN, relay, flasher, indicator, TDM 850 4TX, TDM850, 4TX, blink, bulbs, LED
