Cylinder Identification Sensor
19 replies to this topic
#1 LeonWolf
LeonWolf
  • 20 posts
Posted 02 June 2019 - 02:37 pm
I have a code 11 on my 2003 900. It was the only code. I have today swapped it out for the speed sensor as advised and I'm still getting code 11. I'm a bit lost now, any help would be great please, new to these had this bike, my first TDM for only a month and it's currently a frame with a nose cone. At the point of scrapping it
#2 LeonWolf
LeonWolf
  • 20 posts
Posted 02 June 2019 - 03:10 pm
Just realised I have an 02 bike on an 03 plate and I have the dodgy ECU number. Will this still be changed by yamaha?
#3 SJCA
SJCA
  • 13 posts
Posted 02 June 2019 - 03:48 pm
No harm in asking.
My 02 900 ECU ends in 01. I think the dodgy ones end in 00.
#4 LeonWolf
LeonWolf
  • 20 posts
Posted 02 June 2019 - 03:53 pm
Mine matches the one on here pictured with the same numbers exactly as mine
#5 LeonWolf
LeonWolf
  • 20 posts
Posted 02 June 2019 - 03:58 pm
Read it wrong mines been replaced but solved one issue, why new looms wouldn't work I was ordering 03 ones but it's an 02 on an 03 plate. So back to square one, code 11 even after swapping with speed sensor. Starting to loose faith
#6 dablik
  • 10,893 posts
Posted 02 June 2019 - 05:33 pm
I'm pretty sure but not a 100% positive that 2002-2003 should be the same, far as i'm aware any changes came in 2004 ??
#7 LeonWolf
LeonWolf
  • 20 posts
Posted 02 June 2019 - 06:50 pm
Yeah I thought they would be but I've had 2 2003 looms and there are 3 connectors that are a different size
#8 LeonWolf
LeonWolf
  • 20 posts
Posted 02 June 2019 - 07:34 pm
And on a 2002 loom on ebay the connectors look the right ones
#9 dablik
  • 10,893 posts
Posted 02 June 2019 - 08:04 pm
If the connectors are a different size but do they still have the same number of wires going into them, because you can swap over connectors..
#10 LeonWolf
LeonWolf
  • 20 posts
Posted 02 June 2019 - 11:23 pm
No there is far too many wires in my connectors than the corresponding one on replacement loom
#11 LeonWolf
LeonWolf
  • 20 posts
Posted 03 June 2019 - 01:38 pm
After changing the sensors over do I need to manually clear fault code or will it rectify itself
#12 dablik
  • 10,893 posts
Posted 03 June 2019 - 03:38 pm
Cant remember, think once you've rectified the problem error should not be showing, have you looked on JBX at all.
#13 Rallyist
Posted 03 June 2019 - 03:42 pm
You have to clear all notifications
#14 LeonWolf
LeonWolf
  • 20 posts
Posted 03 June 2019 - 04:24 pm
And how do you do that please, can't find info on net
You mean fix and they will clear or ones fixed you have to manually clear codes
#15 LeonWolf
LeonWolf
  • 20 posts
Posted 03 June 2019 - 04:56 pm
Yes mate had some good info from there so far
#16 Rallyist
Posted 04 June 2019 - 06:40 am
check JBX page on Diag mode codes 60 - 70 https://www.tdm-yama...t.org/?page=MDG
#17 wicklamulla
Posted 07 June 2019 - 12:44 am
i would imagine there is a part number on the loom if ya look carefully,  if not ask a dealer to check the part number of a 2002 loom versus a 2003 loom.
#18 fixitsan
  • 4,850 posts
Posted 28 June 2019 - 09:12 pm
How about tracing the wires back to the other end, probably at the ECU, through each connector.
Put a multimeter or bulb&battery across the wire to check continuity, if you have continuity then the wire is good so just pay close attention to the crimped terminals at the ends. Just need to check the wire for signs of rubbing  and catching on other fixtures
If you have good continuity and good spades, then you're unlikely to have a fault which can be fixed with a new loom, or so i would think !
Edited by fixitsan, 28 June 2019 - 09:30 pm.
#19 wicklamulla
Posted 29 June 2019 - 10:03 am
Looks loike he's had enuf and is breaking it as there are parts listed in the fer sale section.
#20 fixitsan
  • 4,850 posts
Posted 29 June 2019 - 03:25 pm
What a pity... that's life though
