900 Ecu Flash
18 replies to this topic
#1 tdmcullen
tdmcullen
  • 25 posts
Posted 10 July 2019 - 09:13 am
Has anyone ever got the engine control module flashed on their 900. Mine is 2007 and can't get my hands on a power commander so thinking of getting it flashed instead. Also where would you recommend to get it done, some places you can post them the ECU and they do it and post back. Any advice?
#2 wicklamulla
  • 11,536 posts
Posted 10 July 2019 - 10:40 am
how ya.  http://www.carpe-tdm...34683&hl=samios
#3 tdmcullen
tdmcullen
  • 25 posts
Posted 10 July 2019 - 01:55 pm
Interesting read, cheers. I sent them an email.
#4 tdmcullen
tdmcullen
  • 25 posts
Posted 10 July 2019 - 03:26 pm
I got an email back from them, apparently my ECU is a rare part no. And he hasn't flashed one before. Has anyone with the following ECU got it done:
5PS-8591A-20
#5 fixitsan
  • 3,469 posts
Posted 10 July 2019 - 05:47 pm
I had mine done. Part number ends -01.
9'er with a 17" front wheel and Samios remap  :)  happy days
#6 tdmcullen
tdmcullen
  • 25 posts
Posted 10 July 2019 - 05:51 pm
Yea the one that ends in 01 is the common one, mine ends in 20 which isn't too common so need to find someone that can do that one.
#7 fixitsan
  • 3,469 posts
Posted 10 July 2019 - 06:17 pm
I haven't seen many '-01' ones, lots of 02's and 10's though.
If you don't have ABS or an immobiliser I think they early 01 ECU would work
#8 tdmcullen
tdmcullen
  • 25 posts
Posted 10 July 2019 - 07:21 pm
Mine has abs and an immobiliser, is the ECU coded to the immobiliser? Does getting a flash affect that?
#9 fixitsan
  • 3,469 posts
Posted 10 July 2019 - 07:31 pm
The immobiliser has a separate box, coded to the ECU (from what I'm told)....is there a key trasponder too ? I'm Not sure.
The ECU can be flashed only in the area of the memory where the maps are stored, the immo code is in a different part of memory and won't be changed by rewriting of the maps
#10 tdmcullen
tdmcullen
  • 25 posts
Posted 10 July 2019 - 07:35 pm
Thanks, that's what I thought. Would you recommend a flash over a power commander?
#11 fixitsan
  • 3,469 posts
Posted 10 July 2019 - 11:37 pm
The 64 gazillion £ question....
Never had a PC but I can imagine it's good points.....but you're still stuck with the standard ignition timing map. An ECU remap let's the tuner open up the benefits of being able to adjust the timing too
#12 chrisr
  • 1,442 posts
Posted 11 July 2019 - 08:29 am
Samios couldnt flash mine either, and using Fixitsans ecu the bike wouldnt start.This is my ecu no.Attached File  3C970DA5-37B6-4516-90FE-9384E6EB0163.jpeg   162.38KB   1 downloads
Edited by chrisr, 11 July 2019 - 08:33 am.
Black.Registered 2013.Scorpion Cans. Renthal 755s, Hyperpro front springs,15w fork oil,DL650 handguards,givi engine bars,led spotlights,gipro gear indicator,lengthened dogbones,LeeHenty CSM kit and stainless bits,Topsellerie seat,Nitron rear shock,MRA vario screen,grip puppies.PC III. K&N airfilter,Fenda extenda,
#13 tdmcullen
tdmcullen
  • 25 posts
Posted 11 July 2019 - 09:07 am
Samios couldnt flash mine either, and using Fixitsans ecu the bike wouldnt start.This is my ecu no. 3C970DA5-37B6-4516-90FE-9384E6EB0163.jpeg
Did you find anyone that could flash yours?
#14 chrisr
  • 1,442 posts
Posted 11 July 2019 - 09:26 am
No, I had a Powercommander on my previous bike that I swapped over and had remapped, it runs really well now, but so does my previous one without the pc! I may try going back to standard exhausts at some point to see what that does, I rode AliG’s two Tdm’s at the weekend, a 2004 (my old one) and a 2010, both run perfectly with a standard setup.
#15 wicklamulla
  • 11,536 posts
Posted 12 July 2019 - 12:20 am
Samios couldnt flash mine either, and using Fixitsans ecu the bike wouldnt start.This is my ecu no.attachicon.gif 3C970DA5-37B6-4516-90FE-9384E6EB0163.jpeg
surely it wouldn't start as the Immobiliser and Fixitsans ECU were not compatible,  what ye think?
#16 chrisr
  • 1,442 posts
Posted 12 July 2019 - 07:36 am
I think you’re right, but I didn’t want to get in to removing the immobiliser.....if that’s even possible
#17 wicklamulla
  • 11,536 posts
Posted 12 July 2019 - 09:00 am
i gotta admit i too would be worried it may be 'tamper proof' and lock out if messed with. I reckon they could be made to communicate and work properly but it's more money and a risk!
#18 fixitsan
  • 3,469 posts
Posted 12 July 2019 - 11:42 am
Be cheaper to fit an earlier and non immobiliser version wiring harness
EG https://rover.ebay.c...tm/293124583064
Edited by fixitsan, 12 July 2019 - 11:45 am.
#19 tdmcullen
tdmcullen
  • 25 posts
Posted 12 July 2019 - 01:03 pm
Anyone ever heard of these? Just came across them. Look similar to a power commander.
https://jetprimeshop...c-cjp-112h.html
