Kedo L E D Rear Light Unit Fail
2 replies to this topic
#1 Favs
  • 3,093 posts
Posted 11 July 2019 - 06:03 pm
While putting the toys to bed (02:00 Wednesday), I noticed that the number plate lamp was flashing and only lit on one side.
Looks like this https://www.ebay.co....tm/372681628526 (but not that ££££) - dunno if KEDO still do em.
Investigation/repair this morning....
Unit removed and opened
3/5 White LEDs not working  :punishment: lazy so an so's
After determining the problem with MMeter I decided that dismounting the offending part and replacing the busted resistor wasn't worth the effort.
I cut a 6 LED piece from one of the LED strips I use to light the shed. I soldered a couple of wires to the strip and glued into position on the light unit. Soldered the wires to appropriate poles and we have light. A mask off and quick coat of black gloss to prevent some unwanted white light  showing.
Assemble followed by carroty cake and tea as reward.
:good:
#2 Pantboy
Pantboy
  • 796 posts
Posted 11 July 2019 - 06:39 pm
The number plate lamps flicker on my kedo unit too, you fancy fixing mine?
#3 Favs
  • 3,093 posts
Posted 12 July 2019 - 10:04 am
S'easy fix if ya got a 10mm box key / deep socket to remove the rear light - no need to dismantle any other parts for removal. (warm and flexible plastics - maybe not on a winter's day). ;)
