Unknown Connector Under Seat
8 replies to this topic
#1 Norwegian
Norwegian
  • 162 posts
Posted 14 August 2019 - 09:08 pm
What are these connectors for, I wonder? Well tucked in on the left side under the seat. I assume one is for a (nonexistent) alarm, but the others?
I tapped #3 for a switched 12V+ to the relay for my glorious new cheap chinese heated grips, and what a treat. With my hand protectors they'll really extend the season here in the arctics.
Edited by Norwegian, 14 August 2019 - 09:10 pm.
#2 fixitsan
  • 4,856 posts
Posted 14 August 2019 - 11:25 pm
I think...2 is a bunch of grounds (there's another near the ECU), 3 is the alarm , and 1 is at least the brake light....disconnect it and see what stops working ?
#3 Norwegian
Norwegian
  • 162 posts
Posted 15 August 2019 - 06:15 am
None are connected. 2 has a blank lid (may well be grounds), 3 has a lid with a loop between 2 out of 6 terminals (probably alarm), and 1 is a strange threeprong one sealed with some rubbery sealant and also with a loop between 2 terminals.
#4 fixitsan
  • 4,856 posts
Posted 15 August 2019 - 08:08 am
Ah yes i didn't spot that, 3 is so close to the connector for the rear lights, which is tucked around the frame probably, just in the same area, I mistook it for that.
Time to get a voltmeter out, if you really must know
#5 jiff
jiff
  • 693 posts
Posted 15 August 2019 - 09:10 am
.....fwiw.....on my 4Tx I connected the heated grips to the rear brake light.....
as instructed on here
Jiff
#6 TDM4ever
TDM4ever
  • 302 posts
Posted 16 August 2019 - 06:35 am
Jiff
So, they only heat when you brake.... :P
#7 jiff
jiff
  • 693 posts
Posted 16 August 2019 - 08:35 am
.......or maybe it’s to inform those behind me that my hands are warm !
#8 dapleb
  • 18,399 posts
Posted 16 August 2019 - 10:42 am
Lolzio
#9 wicklamulla
Posted 16 August 2019 - 12:00 pm
  cracked me up!
