Solved! Tdm 850 4Tx Ignition Issue
ignition alarm electrical wiring start
10 replies to this topic
#1 browncastle
browncastle
  • 7 posts
Posted 07 September 2019 - 11:25 am
Hi there all!
I have recently bought a 4TX 2001 with 30.000km on the clock.
While installing heated grips I figured out that i would clean up what i thaught was old power thiefs for electrical acessories.
It was a fair lot of unisolated cables with suspicious connectors and I went to work to clean it up.
Unfortunately, I was to eager and cut two cables togheter and shorted something.
After this the bike wouldnt start. I googled a bit and searched this forum a lot and figured that I had cut the wiring from a OEM optional alarm system called Cyclelok.
I also found a RV99 supplementary service manual that shows connectors for the alarm system. Unfortunately, in my possesion the bike have never had this connectors, only a spaghetti look-alike with black-only cables.
I started fault finding with my multimeter and found that the fuel pump was faulty. So I changed that. I have guess-connected two of the cables togheter so the bike will now turn over and the fuel pump works.
I have spark on both cylinders, but they are a bit weak in my opinion ( no previous experience with yamaha).
When i try to start it ticks over fine, fuel pump runs as it should and i have spark, but after a while it backfires tremendously loud out the exhaust.
Any good suggestions ?
Cheers from Norway.
Edited by browncastle, 29 September 2019 - 07:06 am.
#2 Studley Ramrod
Posted 07 September 2019 - 02:01 pm
Hi and welcome.  Difficult to know what's causing the backfire, it may be that the carbs need cleaning if the bike has been unused for a while.  It could also be air getting in past the inlet rubbers between the inlet and the carbs.  The rubbers tend to crack and harden over time.
#3 browncastle
browncastle
  • 7 posts
Posted 07 September 2019 - 05:47 pm
Bike was in daily use until this happened. No running problems and very fresh fuel. I suspect faulty wiring or ignitor module.
#4 drewpy
  • 1,788 posts
Posted 07 September 2019 - 08:24 pm
Check your earths, make sure you have good clean grounds
#5 Studley Ramrod
Posted 08 September 2019 - 10:19 am
I wonder if a coil could be on it's way out.  They can run normal then start playing up when warmed up.
#6 browncastle
browncastle
  • 7 posts
Posted 08 September 2019 - 02:35 pm
One of the 7 black cables to the alarm system supplies constant 12 v from battery. This must be for the remote reciever. Another supplies 12v when ignition on. I wonder if this cable have to be connected to something ? Anyone that could take a look at the wiring diagram to help me ?  last page in this link http://www.journey.c...TDM850 rv99.pdf
#7 chrisr
Posted 09 September 2019 - 07:15 am
After you shorted something did you check all the fuses?
#8 browncastle
browncastle
  • 7 posts
Posted 09 September 2019 - 05:37 pm
Jup, signal fuse blew but replaced it.
#9 browncastle
browncastle
  • 7 posts
Posted 29 September 2019 - 06:43 am
Solved, bought a used wiring loom on ebay with the oem alarm connectors and shunts intact. Works like a charm now.
#10 Favs
Posted 29 September 2019 - 06:59 am
Great news. Enjoy.
#11 Studley Ramrod
Posted 29 September 2019 - 02:30 pm
If in doubt, swap it out. :)  Enjoy.
Also tagged with one or more of these keywords: ignition, alarm, electrical, wiring, start
