Bondy's 4Tx Carbs
15 replies to this topic
#1 bondy
bondy
  • 860 posts
Posted 11 September 2019 - 01:47 pm
Hello All,
Bike has been MOT'd today but just needs a couple bits sorted before it's ready.
One issue is with the carbs. During a test ride yesterday it won't pull cleanly above 4000rpm with the choke in. With the choke out it played ball.
The carbs have been stripped and ultrasonically cleaned and rebuilt with a rebuild kit, including tubes. It idles ok and new airbox to carb rubbers are on order as the originals are hard.
Are there any other area's which could cause this issue.
Ta
Bondy.
#2 Studley Ramrod
Posted 11 September 2019 - 03:17 pm
My first thoughts would be the fuel levels, are they within factory specs ?
Second would be the needle height, are they set to factory spec ?
Difficult to know for sure though, might be that something wasn't refitted correctly, diaphragms, jets, etc.  Might even be the inlet rubbers you mention.
#3 bondy
bondy
  • 860 posts
Posted 11 September 2019 - 04:01 pm
Hi Studders,
yep had mooch about on the search engine and badly fitting/old carb to airbox rubbers seem to cause these types symptoms so will change them first rather than rip the carbs out again.
Will you keep you'all posted on progress.
Ta Muchly
Bondy.
#4 Studley Ramrod
Posted 11 September 2019 - 05:08 pm
:good:
#5 bondy
bondy
  • 860 posts
Posted 11 September 2019 - 05:28 pm
Just had it confirmed that everything went back as per factory spec (and knowing the guying doing it I wouldn't doubt him) so hoping it's just the rubbers. I'm getting desperate to get the bugger back and learn to ride again, been 6 years since the last time.
Getting twitchy
Bondy.
P.S.
during his test ride yesterday he did admit he loiked it, not bad for a chap that doesn't do anything post 1980's  :good:
#6 dapleb
  • 18,394 posts
Posted 11 September 2019 - 08:03 pm
There is a silly cone mod to old rubbers if ewe can't wait fur new juans.
#7 Studley Ramrod
Posted 11 September 2019 - 08:04 pm
Oooh, 6 year twitch is a looooooong time. :lol:
#8 butcher650
butcher650
  • 619 posts
Posted 12 September 2019 - 09:46 am
http://www.carpe-tdm...ers#entry168819
#9 dandywarhol
Posted 12 September 2019 - 12:57 pm
Hmmmm, 4000rpm is the default for the TPS setting when setting it up with the tachometer
Edited by dandywarhol, 12 September 2019 - 12:57 pm.
#10 bondy
bondy
  • 860 posts
Posted 12 September 2019 - 03:51 pm
Thanks wee man, have passed on the info.
And belated burpday wishes.
#11 dandywarhol
Posted 12 September 2019 - 04:25 pm
Cheers - I forgot you wouldn't know a camshaft from a calm day...................................... :hide:  :pimp:
#12 bondy
bondy
  • 860 posts
Posted 12 September 2019 - 05:34 pm
:uhmyeah:  :rotflmmfao: You know me so well. MGB is still in various sheds and garages.
If the new rubbers aren't any good then that's the next plan.
Edited by bondy, 12 September 2019 - 05:32 pm.
#13 Studley Ramrod
Posted 13 September 2019 - 09:05 am
Think you might be confusing inlet rubbers with carb to airbox rubbers chaps.
#14 MipeTDM
MipeTDM
  • 92 posts
Posted 18 September 2019 - 03:36 pm
Have you checked the carb diaphragm rubbers, the ones that move the slides?
I've had some similar issues, turned out that one of the two was torn.
#15 bondy
bondy
  • 860 posts
Posted 18 September 2019 - 04:13 pm
Ta muchly, I'll let my mech know but I suspect he would have check them when he rebuilt the carbs.
Boop.
#16 Favs
Posted 18 September 2019 - 04:24 pm
Has everyone, apart from me n Splodge, forgotten about wintergreen?
Here's an example https://www.youtube....h?v=9eTF6tnYYdc lots of other vids to watch too........
