Chain Slack
10 replies to this topic
#1 DaveW
DaveW
  • 21 posts
Posted 29 September 2019 - 10:45 am
As a new rider of a TDM I'm lacking in confidence that I've got the chail slack correct. The book says 40 to 50 mm for my 850 but this seems very slack and different from anything I've come across before. Why so loose on TDMs?
#2 Hombre
Hombre
  • 407 posts
Posted 29 September 2019 - 11:29 am
The relationship between the drive sprocket, the swing arm pivot and the swing arm length together with the suspension travel, dictate how much slack will be needed. As the suspension compresses, the slack reduces. If at the tightest spot there is no slack, the load on the output shaft bearing causes failure.
BSA C15T, Ducati 200 Elite, Villiers Cub Trials Bitsa, Ariel Huntmaster, AJS 650 CSR, Sunbeam S7, Suzuki 650 Katana, Honda 400-4, Bultaco 350 Sherpa, Cotton Minarelli, Fantic 303, Yamaha SRX 400, Yamaha 550 Virago, Kawasaki ZZR 1100,  Fantic 305, Yamaha TDM 850 '91, Yamaha TDM 900 '04.  Ducati 200 Elite (again).
#3 jiff
jiff
  • 650 posts
Posted 29 September 2019 - 11:34 am
.....or maybe to paraphrase Hombre, or add a conclusion, perhaps........that amount of slack is correct......we are told
#4 DaveW
DaveW
  • 21 posts
Posted 29 September 2019 - 11:43 am
Thanks guys. I'll go with.
#5 Studley Ramrod
  • 17,269 posts
Posted 29 September 2019 - 02:34 pm
Yup, Hombre is spot on.
Not enough slack and you'll hear the output shaft bearing whine.  Too much slack and you'll feel the chain backlash when you decellerate.
#6 dapleb
  • 16,538 posts
Posted 29 September 2019 - 02:59 pm
If anyone ever decides to argue the point with you....sit on boike and say "and now". :0)
#7 chrisr
  • 1,495 posts
Posted 29 September 2019 - 04:04 pm
50-60mm on a 900. If you ever have a new tyre put on the rear always check they haven’t taken the slack out.
The Black One : 2010 Model Registered 2013 owned 2018 - present.Scorpion Cans. Renthal 755s,15w fork oil,DL650 handguards,givi engine bars,led spotlights,gipro gear indicator,shortened dogbones,LeeHenty CSM kit and stainless bits,Topsellerie seat,MRA vario screen,grip puppies.PC III (dynoed). K&N airfilter,Fenda extenda.
#8 DaveW
DaveW
  • 21 posts
Posted 29 September 2019 - 04:42 pm
Ok. Will do thank you.
#9 AliG
  • 1,262 posts
Posted 29 September 2019 - 05:16 pm
And if you take it for an MOT where they are unfamiliar with the model, they may question it. I had a Yamaha dealer try to give me an advisory on slack chain, until I challenged him to check the spec in a workshop manual. I got a pass and no advisory. Went somewhere new this year and had the handbook in my pocker just in case.
2012 900 - Black. Still adding shiny bits
2019 Royal Enfield Himalayan in white with Yamaha handlebars
#10 DaveW
DaveW
  • 21 posts
Posted 29 September 2019 - 05:30 pm
Funny you should say that. I got an advisory earlier this year. I let it pass at the time but actually thought that the chain was ok according to the book.
#11 dablik
  • 8,944 posts
Posted 29 September 2019 - 06:55 pm
Yup happened to me last MOT and i sat on it, got real tight :)
Quad 900 Silver Laser duo tech pipes-Scott oiler-Engine crash bars- Radiator mounted see me ring LED's-Datatool system 3 alarm -Centre stand- Extender fender-Renthal bars-Handle bar risers-Mirror extenders-BMW GS Handgaurds-Acumen uprated horn & Nautilus-Stainless steel Radiator guard-Givi wing rack-OEM screen-Yammy touring screen-MRA Vario-MRA Double bubble cut down for fast as fk riding-Tiger screen-Tank protector-Stomp grip panels-Optimate lead
1991 MK1 in need of some TLC watch this space  :) Sorted and on the Road Mick :P :P it's the bike that Jack built ;)
