* * - - - 1 votes
New Owner
10 replies to this topic
#1 Cayennepepper
Cayennepepper
  • 5 posts
Posted 01 October 2019 - 12:20 pm
Hi,
I've just picked up a TDM 900 ABS 2005 model with just 4000 miles on the clock (I'm in Guernsey) and loving the bike so far and will be doing a service, brakes etc before the winter weather properly arrives.
What oil do you guys recommend?
The bike has a main stand, Givi top box and after market screen, are there any other recommended modifications?
Also, it feels like the font brake discs are slightly warped, I've had a search on the internet and can't find any other reports, there's a few posts on here from ages ago. Any tips to check if it's discs or calipers?
Is this a known issue and does anyone have recommendations for after market discs and pads as the OE ones look mega expensive!
Also, is there a link to the standard suspension settings, I was expecting soft but these are very bouncy. I'm 14 stone so if any similar weight riders have suggestions they'd be gratefully received
Any recommendations for tyres - the current ones have plenty of tread but are 15 years old so not too grippy!
Sorry to ask so many questions but always best to hear from owners!
My other bike is an Intruder 1800  which is going to be pampered this winter and treated to a makeover
#2 fixitsan
  • 3,635 posts
Posted 01 October 2019 - 12:28 pm
Hi,
I'm 17 stone and so i would the rear spring preload up and also had the rear shock rebuilt.
Bbounciness' is effectively a lack a of damping, so turning up the rebound and then compression till satisfied will be the way to go. If you find that the rebound adjuster is very loose and the detents between the various positions are not clearly defined then the shock is almost certainly beyond it's best.
9'er with a 17" front wheel and Samios remap  :)  happy days
#3 Favs
  • 3,482 posts
Posted 01 October 2019 - 12:53 pm
Greetings
Tyres are personal - lots of differing opinions are available. ;)
DTI the discs with calipers off (run out) & straight edge for concave (wheel out for the latter).
BTW its not the ABS you're feeling is it (are you last  on the brakes)? ABS light will flash
Edited by Favs, 01 October 2019 - 03:35 pm.
#4 dapleb
  • 16,538 posts
Posted 01 October 2019 - 01:51 pm
Hello dare,
There are a few opinions on tyres ear http://www.carpe-tdm...=78#entry373311
Brakes, if it is the discs....then summat warped them. So I would start by making sure the calipots aren't binding and go from there.
#5 jpor
jpor
  • 66 posts
Posted 01 October 2019 - 03:25 pm
My personal experience is the bluespots do bind. I use the front brake for a lot of slow speed control which is when you can really tell if they bind and with the clutch in it'll surge a little as the brakes bind and unbind. Mine are doing it again at the minute, probably the weather flicking some mucky stuff in round the dust seals.
My front suspension feels okay (I'm 14 stone), what did you ride before? It could just be a case of it all being relative if it was something like a sports bike? Failing that, if the tyres are 15 years old, I dare say the fork seals are going to blow the first time you hit a pot hole anyway, but I imagine new fork oil will solve your problem. Do a coolant flush, I didn't when i got mine and it had been sat so my thermostat and water pump went in the first few thousand miles of ownership. It's been pretty good for the last 30k miles or so
Edited by jpor, 01 October 2019 - 03:26 pm.
#6 Cayennepepper
Cayennepepper
  • 5 posts
Posted 01 October 2019 - 04:30 pm
Thanks all for your responses, very helpful. A very different ride to my 1800 Intruder so probably need to get used to much bigger suspension travel.
Good call re the brakes binding, yes it is just at low speed so Ill get the pads out over the weekend and give them a good clean up with brake cleaner and check the pads for uneven wear.
Fork seals are fine, no issues at all but no doubt the fork oil is past its best so thats definitely one for the list.
Does anyone have a link to the standard suspension settings, think thats the best place to start from.
Also, I dont like the chrome bars, any suggestions for something a bit wider?
Edited by Cayennepepper, 01 October 2019 - 04:32 pm.
#7 Riggers
Riggers
  • 501 posts
Posted 01 October 2019 - 05:03 pm
Hi, and welcome to the forum.
There are full workshop manuals available and loads and loads of other stuff available here....
https://www.tdm-yamaha.heliohost.org/
Happy riding and reading!
Riggers.
#8 TKH
  • 2,083 posts
Posted 01 October 2019 - 06:13 pm
Is it the standard suspension/springs on the bike? Did the previous owner have a pillion most of the time and maybe set things up for that?
When doing the chain tension, it needs to be 50-60mm.
The link to JBX's site from Riggers will give you loads of info and tips. You can also search to forums on here for help.
2008 black 900, Stebel 134db, Givi 42 ltr top box, Kapa rack, ciggy lighter, heated grips, BMW hand guards, tank bag, soft panniers, PR2s front and rear, K&N airfilter, airbox mod.,Bikevis lights, handlebar offset risers,
#9 Cayennepepper
Cayennepepper
  • 5 posts
Posted 01 October 2019 - 07:19 pm
Thanks guys, yes suspension all stock, just need to firm up the front a bit. The link to JBX is perfect thanks, plenty to keep me going. I look forward to doing some work over the next few weeks and posting some updates.
#10 gautrek
gautrek
  • 57 posts
Posted 01 October 2019 - 09:11 pm
I do think I may need to play about with the suspension on my 4TX. But the thought of messing with it fills me with dread. So I think I'll just leave well alone.
#11 chrisr
  • 1,495 posts
Posted 01 October 2019 - 10:16 pm
Oil should be JASO ma spec, I usually just get the cheapest available on e bay. Ive had various Michelin road pilots which have been good but currently have a pair of Avon Storm 3D XMs which are also very good and much cheaper. I have Renthal 755 bars which stop you getting the pain in the wrists the oem bars give you, not sure theyre any wider though. Make sure you get the rear suspension linkage apart and grease the bushes and bearings, plenty on this forum about that! And welcome!
Edited by chrisr, 01 October 2019 - 10:17 pm.
The Black One : 2010 Model Registered 2013 owned 2018 - present.Scorpion Cans. Renthal 755s,15w fork oil,DL650 handguards,givi engine bars,led spotlights,gipro gear indicator,shortened dogbones,LeeHenty CSM kit and stainless bits,Topsellerie seat,MRA vario screen,grip puppies.PC III (dynoed). K&N airfilter,Fenda extenda.
