High Revs At Tick Over When Engine Warm
2 replies to this topic
#1 nojohntitan
nojohntitan
  • 26 posts
Posted 09 October 2019 - 09:37 pm
engine is staying at high revs when warm and throttle closed I tried pushing cold start unit bar from right hand side revs drop, but when releasing bar revs rise once again?
#2 chrisr
  • 1,495 posts
Posted 09 October 2019 - 11:16 pm
First thing to do is clean and grease cold start mechanism, I suspect that is stuck, especially if nothing else has been touched. You could use the knob under the frame on the rhs of the bike to lower the revs, but that is just masking the problem. Plenty of info on here on how to remove the csm. You could also try whacking the bar to try and shock it free, but if that doesnt work you really need to clean it.
Edited by chrisr, 09 October 2019 - 11:18 pm.
The Black One : 2010 Model Registered 2013 owned 2018 - present.Scorpion Cans. Renthal 755s,15w fork oil,DL650 handguards,givi engine bars,led spotlights,gipro gear indicator,shortened dogbones,LeeHenty CSM kit and stainless bits,Topsellerie seat,MRA vario screen,grip puppies.PC III (dynoed). K&N airfilter,Fenda extenda.
#3 TKH
  • 2,083 posts
Posted 10 October 2019 - 11:24 am
+1 for cold start mech.
Easy enough to do, just takes time - tank up, airbox off, remove cold start mech. Overhaul the mechanism. Refit everything. I found the screws that hold it on a bit awkward.
Easy enough whether you're handy with the spanners or a beginner.
2008 black 900, Stebel 134db, Givi 42 ltr top box, Kapa rack, ciggy lighter, heated grips, BMW hand guards, tank bag, soft panniers, PR2s front and rear, K&N airfilter, airbox mod.,Bikevis lights, handlebar offset risers,
