Starting Problems
15 replies to this topic
#1 Philtaylor1968
Philtaylor1968
  • 12 posts
Posted 27 October 2019 - 04:17 pm
Hi guys, my 91 tdm will not start, battery is good,starter motor good, relay switch good,starter cut off relay good, there's nothing when I press the button!...is there anything else I should be checking.kind regards phil.
#2 PICARD
  • 1,336 posts
Posted 27 October 2019 - 04:28 pm
The button and fuse to begin with.
#3 Studley Ramrod
  • 17,294 posts
Posted 27 October 2019 - 05:12 pm
Hi.
Also worth checking that it's not in gear.  The sidestand switch might also be sticking.
#4 dablik
  • 8,959 posts
Posted 27 October 2019 - 10:31 pm
Check contiuity between the ignition and fuse, wire has been known to corrode inside the switch housing and side stand switch can give intermittant reading when they become corroded inside, can come apart to be sorted, you checked battery connection !
Quad 900 Silver Laser duo tech pipes-Scott oiler-Engine crash bars- Radiator mounted see me ring LED's-Datatool system 3 alarm -Centre stand- Extender fender-Renthal bars-Handle bar risers-Mirror extenders-BMW GS Handgaurds-Acumen uprated horn & Nautilus-Stainless steel Radiator guard-Givi wing rack-OEM screen-Yammy touring screen-MRA Vario-MRA Double bubble cut down for fast as fk riding-Tiger screen-Tank protector-Stomp grip panels-Optimate lead
1991 MK1 in need of some TLC watch this space  :) Sorted and on the Road Mick :P :P it's the bike that Jack built ;)
#5 wicklamulla
  • 11,861 posts
Posted 27 October 2019 - 11:27 pm
ensure the ignition switch is flushed out with contact cleaner and the key is making good contact.
#6 dapleb
  • 16,547 posts
Posted 28 October 2019 - 04:55 am
Hello dare and welcome. Hope you get it sorted.
#7 Philtaylor1968
Philtaylor1968
  • 12 posts
Posted 28 October 2019 - 05:24 pm
Thanks lads for the advice, I will try these ideas on Saturday and update you all.
#8 Bjørge
  • 1,493 posts
Posted 29 October 2019 - 09:29 am
....and you haven't activated the kill switch? 😎
Welcome, by the way!
Edited by Bjørge, 29 October 2019 - 09:30 am.
#9 mh1848
mh1848
  • 470 posts
Posted 29 October 2019 - 07:02 pm
have you shorted the solenoid to see if it spins and starts? - used to have to carry a screwdriver to do that on one of my old bikes that had intermittent fault
neutral light is in the circuit as well as clutch switch and sidestand
#10 divvxj
divvxj
  • 1,292 posts
Posted 31 October 2019 - 01:57 pm
silly i know but have you tried wiggling the key in the barrel , had problems with this , had to much stuff attached to the key ring , too much weight
#11 Philtaylor1968
Philtaylor1968
  • 12 posts
Posted 06 November 2019 - 07:40 pm
so you mean put a screwdriver onto the two connections on the solenoid to jump the solenoid switch itself, thus cranking the motor?
#12 mh1848
mh1848
  • 470 posts
Posted 07 November 2019 - 06:33 pm
yes - if it is the starter switch in handlebars that is u/s will still fire up - i had some problems with the stater relay block connectors - had tested relay with circuit as shown in manual and also checked all the other switches - side stand, clutch, neutral light and starter button - eventually discovered it was corrosion on one of the pins in the block connector -
#13 Philtaylor1968
Philtaylor1968
  • 12 posts
Posted 15 November 2019 - 07:49 pm
Thanks a lot mate I'll look at that. Excuse my ignorance, but which exactly is the starter relay ? It's one of those little black ones situated under petrol tank?, Does it have a part number? Kind regards and thanks for your help, Phil.
#14 mh1848
mh1848
  • 470 posts
Posted 19 November 2019 - 06:47 pm
hi apologies for delay in responding - yes the relay is the larger one that is on side of battery on rubber clip - think i have a spare if you PM me
#15 Philtaylor1968
Philtaylor1968
  • 12 posts
Posted 23 November 2019 - 09:32 am
Hi, I've pm,d you mate.
#16 Philtaylor1968
Philtaylor1968
  • 12 posts
Posted 01 December 2019 - 05:46 pm
I've sent my details mate.
