Help Required To Wire Up A Motor For My Drill
9 replies to this topic
#1 madmopedracer
madmopedracer
  • 473 posts
Posted 22 November 2019 - 09:17 am
got a good deal on a old pillar drill unfortunately it had a 3Ph motor .
but i had a spare single phase but it rotates the wrong way .
i can find info on the interwed on a 4 terminal motor but not 5 terminal
#2 ramo
ramo
  • 1,194 posts
Posted 22 November 2019 - 10:29 pm
Does the 1 phase rotate the wrong way or the 3 phase, I assume its the 1
#3 Studley Ramrod
Posted 23 November 2019 - 08:56 am
How's about a 1 phase to 3 phase convertor ?
#4 madmopedracer
madmopedracer
  • 473 posts
Posted 23 November 2019 - 11:59 am
its a single phase motor took the 3 phase off
Edited by madmopedracer, 23 November 2019 - 12:00 pm.
#5 TKH
  • 2,201 posts
Posted 23 November 2019 - 02:32 pm
Did you go the connecting wires from live and neutral? They don't look right to me. Might be wrong.....
#6 madmopedracer
madmopedracer
  • 473 posts
Posted 23 November 2019 - 03:05 pm
it is as i got the motor iv not touched anything it runs well but in the wrong direction
#7 ramo
ramo
  • 1,194 posts
Posted 23 November 2019 - 09:19 pm
I do know that if a 3 phase motor turns the wrong way you can swap any of the 2 phases around to make it turn the right way,
but thant prob don't help in this case
soz
#8 madmopedracer
madmopedracer
  • 473 posts
Posted 24 November 2019 - 12:05 am
yes tried shifting the l and n also the capacitor wires round maybe its something with the jumper connections.
maybe i should cut my loses and buy a new motor then my bargain isn't as good as i thought
#9 fixitsan
  • 4,855 posts
Posted 27 November 2019 - 12:20 pm
You'll need to identify if it's  an induction motor or if it has brushes. If it's brushed ( a universal motor as used in a power drill for example, which can run on either AC or DC), then  the wires on the brushes, OR on the stator can be reversed.. But if it's an induction motor you will need to identify the field windings and reverse the connections to one of the fields.
https://www.google.c...motor direction
#10 madmopedracer
madmopedracer
  • 473 posts
Posted 27 November 2019 - 04:02 pm
thanks will try and have a look over the weekend
