Neutral Light Does Not Work.
Neutral light.
11 replies to this topic
#1 Oldbikergit
Oldbikergit
  • 10 posts
Posted 12 January 2020 - 11:44 am
Hi I'm a newbie.
Last month I bought 2004 TDM 900. The following day I noticed the neutral light does not come on so I contacted the seller who said it worked ok (being cynical he would say that wouldn't he). Anyway, I've used the bike no problem done a few hundred miles so far. It runs fine. I have other bikes so not always using the TDM. I've checked  everything Bulb continuity the switch I've even fitted another good used switch. Now while I've been doing this for some reason the bike won't start. And green light still does not come on. Can anyone help with suggestions as to what else could be wrong.
#2 Bigbill55
Bigbill55
  • 6 posts
  • TDM model: 1994
Posted 12 January 2020 - 02:40 pm
Sounds like a fault around the switch, not sensing it's in neutral. Original fault could have just been with the light, and it was still sensing neutral, but if it isn't sensing neutral it's like trying to start it in gear. Will it start with the clutch in?
#3 Oldbikergit
Oldbikergit
  • 10 posts
Posted 12 January 2020 - 03:55 pm
Yes Bill. Ive tried with the clutch in. Ive looked at the wiring and it goes into a diode which youll probably know only allows current in one direction only. Could this be the fault. I wouldnt say Im an expert with modern bikes with all these sensors on. Im an old git and Ive had plenty of old bikes.
#4 Bigbill55
Bigbill55
  • 6 posts
  • TDM model: 1994
Posted 12 January 2020 - 06:43 pm
If the starting problem has only happened since you changed the switch and checked the wiring I would double check everywhere you have been before looking at other possibilities, including all plugs and connections. I take it the engine isn't turning over when you state it won't start. If it isn't turning over, I would suspect the starter cut out relay isn't operating, and I would check all circuits connected to the relay, including clutch switch, side stand switch, and neutral switch. I don't think the neutral light is operated directly by the neutral switch, I think it is operated from the ecu. If the bike was starting ok in neutral the neutral switch was probably ok, as I think the light is on another circuit from the ecu.
#5 Oldbikergit
Oldbikergit
  • 10 posts
Posted 12 January 2020 - 10:46 pm
No it wouldnt start before I put a replacement switch in. And yes the engine turns over when trying to start it. Im gonna check all the switches that involve the starting procedure. Also the previous owner fitted spotlights and fancy handlebar indicators so Ill check all this this coming week. Thanks for the info. Ray.
#6 TKH
  • 2,201 posts
Posted 13 January 2020 - 01:12 pm
Hello and Welcome!!
Have you checked to see if your old switch was at fault? Which switch are you talking about? Also assume you've give all the area a good clean? I tend to get more problems with muck and oil ( I like to use a lot of oil on my chain) than with part failures, but it does happen. Mine has a similar symptom at the moment i.e. no neutral light showing. I think I've also got a side stand switch issue it turns over so I've been doing other jobs.
#7 Oldbikergit
Oldbikergit
  • 10 posts
Posted 13 January 2020 - 06:47 pm
Yes TKH. I've tested the old neutral light switch and it's Ok, so I didn't need to buy the used one which is now on the bike. I also like to keep things clean too.
I'll just have to crack on testing the other stuff. I'm ok for wheels as I've got two more bikes. Thanks for your input.
Ray.
#8 leehenty
  • 5,323 posts
Posted 13 January 2020 - 07:41 pm
Get into Diag mode on dash see if any faults show up.
#9 Oldbikergit
Oldbikergit
  • 10 posts
Posted 18 January 2020 - 01:35 pm
Hi Leehenty.
Excuse my ignorance. But what do you mean by 'Get into Diag mode on dash'.
#10 Studley Ramrod
Posted 18 January 2020 - 04:23 pm
Here ya go https://www.tdm-yama...ex.php?page=MDG
#11 Oldbikergit
Oldbikergit
  • 10 posts
Posted 20 January 2020 - 09:08 pm
Well you learn something every day. I'll study this and see where it takes me.
Thanks a bunch. Ray.
#12 Oldbikergit
Oldbikergit
  • 10 posts
Posted 14 March 2020 - 08:25 pm
Hi Again.
Not been on for a few weeks as bike has been at the garage.
The problem has been fixed. It was a control relay that was faulty.
Cheers everyone.
Ray.
