Carbs And Fuel Pipe Routing
Carbs
7 replies to this topic
#1 Jell
Jell
  • 5 posts
Posted 15 April 2020 - 01:46 pm
Hi all, I'm new here and this is my first post.
I have been lucky enough to inherit a 1997? TDM, unfortunately the carbs have been messed around with and the fuel pipes detached from the tank tap.
Question 1, are all 4TX carbs the same or did they vary?
Question 2, is there a diagram for the direction of the pipes?
I'm not sure which model it is but the frame number prefix is JYA4TX and it has a temp gauge as opposed to a fuel gauge(I've seen that question asked)
Thanks in advance, Jell.
#2 Snowbird
Posted 15 April 2020 - 02:42 pm
That's a mk2 then, the key to model year is the code under the seat.
#3 Jell
Jell
  • 5 posts
Posted 15 April 2020 - 03:36 pm
Ok, Ta, I think I worked that much out regarding the numbers 3VD and 4TX, I just wondered if the carbs may have changed through the mk2 4TX range.  I'll take a look under the seat when I get down to where I'm having to work on it.
#4 Studley Ramrod
Posted 15 April 2020 - 03:43 pm
Hi and welcome Jell.
This post might be of help to you, pretty sure the pipe routing to the tap is the same.  http://www.carpe-tdm...6141&hl=petcock
The later mk2a '99-'01 850 has different carbs and an electric fuel pump to that of the '96-'98 850.
#5 Jell
Jell
  • 5 posts
Posted 15 April 2020 - 05:47 pm
Cheers, that is a great help.
Regarding the carbs. Having looked at some I see some(4TX??) have an electrical connector plugged into a solid mounted connector on the side and other carbs have the plug on a short bit of flex, could this be the mk2a '99-'01 type?
#6 dablik
  • 10,892 posts
Posted 15 April 2020 - 06:19 pm
TPS possibly, but i know not much about mk2's, only it's good looking older brother :)
#7 MickC
MickC
  • 432 posts
  • TDM model: 1995
Posted 15 April 2020 - 07:07 pm
MK2 solid connection    MK2a flexi plus the back of the carb (carb to airbox) is about 10mm wider.
#8 Jell
Jell
  • 5 posts
Posted 16 April 2020 - 06:34 am
Great. thanks. Things are getting clearer.
Also tagged with one or more of these keywords: Carbs
