Garmin 590 Issues - Help Needed
13 replies to this topic
#1 Kelpie
Kelpie
  • 944 posts
Posted 06 June 2020 - 07:15 pm
My trusty Garmin 590LM is refusing to acquire satellites.   Any suggestions?  I've done a factory reset and updated it (again) and still no joy.
It's bloody annoying cos I've just managed to fix what I thought was a dodgy battery problem after 3 years!
#2 Snowbird
  • 1,361 posts
Posted 06 June 2020 - 07:27 pm
After a factory reset it may need quite a while for first fix as it will need to download a new almanac from the satellites, there was a date roll back issue on some satnavs last year too.
#3 Kelpie
Kelpie
  • 944 posts
Posted 06 June 2020 - 07:54 pm
Thanks Snowbird.  Wassat mean exactly?  Do I just leave it on for it to do that?
#4 Studley Ramrod
  • 19,217 posts
Posted 06 June 2020 - 07:59 pm
Verify the GPS simulator is turned off.  Also make sure you're outside when trying to locate satellites.
#5 Kelpie
Kelpie
  • 944 posts
Posted 06 June 2020 - 08:25 pm
Did that already.
But... left it for a while and it worked!!  Thanks both.  You've no idea how close I was to f@*"!*g into the nearest hedge!  :lol:
If anyone ever needs a fix for the dodgy battery issue they suffer from, shout.
#6 Snowbird
  • 1,361 posts
Posted 06 June 2020 - 08:53 pm
Probably the cold start thing, the sats are never quite in the right position as they change orbit over time so if not used for too long the gps has to try and get a fix with no idea where the sats are, once it has a link it downloads the latest almanac which is like a list of corrections so it knows where the sats actually are rather than where they should have been, once the gps has that info it should get a fix much quicker, without accurate almanac data the signals may not make enough sense to work out it's position.
You didn't really want to know any of that now it's working again did you.
Disclaimer: I'm a greasemonkey not a navigation expert so all the above could be complete b*llocks but it's how I understand it to work.
#7 Kelpie
Kelpie
  • 944 posts
Posted 06 June 2020 - 08:57 pm
Well I believe you anyway! Im chuffed its sorted. I can map read but prefer to follow the wee box. Thanks again.
#8 leehenty
  • 5,092 posts
Posted 07 June 2020 - 05:12 pm
I also use the low tech backup method of road numbers on paper in my tank bag window.
#9 Kelpie
Kelpie
  • 944 posts
Posted 07 June 2020 - 08:17 pm
I got lazy!! :lol:
#10 Snowbird
  • 1,361 posts
Posted 07 June 2020 - 08:46 pm
For coastal navigation I did the course for working out compass heading and calculating variation and deviation and plotting it all on a chart for dead reconing then working out a tidal vector to get a proper position fix and how to take a transit to confirm, sod that I love my garmin chart plotter, I've forgotten how to do most of it now, do still keep a 30 minute log though so if all goes wrong I know where I was 30 minutes ago and which direction at what speed, I'm sure it will all come flooding back once the brown squidgy feeling running down the back of my leg kicks in.
You gotta love gps.
#11 Studley Ramrod
  • 19,217 posts
Posted 07 June 2020 - 09:44 pm
I have a love hate relationship with satnavs.  Lovely when they work properly but immensely annoying when they do things like recalculating route for no reason, or take you through a city centre as it's 0.2 miles shorter than the countryside route.  I often forget which method I've selected, shortest or quickest and that's when I end up going through Leeds city centre at rush hour after hitting the Home button in Pateley Bridge.  I wanted to go down the A1 FFS !
#12 Kelpie
Kelpie
  • 944 posts
Posted 08 June 2020 - 02:22 pm
I usually like mine! I used to be great at planning routes on the laptop but with changes to software and the onset of old age, Im losing the will to live with planning routes. If we go on tour, we usually make it up as we go along.
#13 dablik
  • 10,759 posts
Posted 08 June 2020 - 04:06 pm
When i'm away i usually sit with a paper map and beer in the evening and plan a route on the sat nav putting plenty of way points in or, when i'm out and about the misses will work out a route on google at home and send info :)
#14 leehenty
  • 5,092 posts
Posted 08 June 2020 - 06:06 pm
I use a garmin 660 in a touratech mount, making it all fit the Royal Enfield was a challenge, but when I got home from Spain had to move it all back to the niner.
I used paper maps too. In hindsight taking the RE that far was a bit mad, the niner will be the long distance tool of choice now.
Edited by leehenty, 08 June 2020 - 06:07 pm.
